New install on previously working system
1 year 1 month ago #335255 by ckuecker
Running 2.9.5 on a RPi 4. I had this system running well earlier, until I tried to update Easy Probe. Now, I can't communicate with the Mesa card on ETH0.
I had to replace my main PC, which wants to use the 192.168.1.x addresses. I changed the jumpers on my 7i96s to 10.10.10.10, and I can ping the card.
When I run LinuxCNC, I get the attached report.
Any suggestions?
1 year 1 month ago #335257 by unknown
If you could your ini & hal files and confirm the IP of the computer you are using. It could be as simple as an in correct IP in your Hal file.
1 year 1 month ago #335276 by tommylight
From your error report:
hm2_eth: ERROR: can't connect: Permission denied
Usually means you have set the IP address on PC same as on Mesa card, the PC must have different last number for IP address, so
10.10.10.11 is OK for PC if Mesa is set at 10.10.10.10
1 year 1 month ago #335279 by ckuecker
Here are the .ini and .hal files.
The static IP of the RPi is 10.10.10.100 - I can ping the Mesa card from the terminal.
File Name: CNC1_2025-09-22.hal
File Size:11.12 KB
File Name: CNC1_2025-09-22.ini
File Size:4.44 KB
1 year 1 month ago #335281 by tommylight
From your hal file
loadrt hm2_eth board_ip="1/0.10.10.10" config="num_encoders=1 num_pwmgens=1 num_stepgens=5 sserial_port_0=0xxxxxxx"
Remove the / from the first 10
