"file ./live/filesystem.squashfs failed the MDS checksum"
11 months 3 weeks ago #337989 by clayton2ndtry
I think I have identified my USB drive from dmesg
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae
root=UUID=d6024873-2470-49d1-992d-a484c0ca8fdf ro initrd=/install/gtk/initrd.gz
lapic quiet rootdelay=5
[ 2.660091] usb usb1: Product: EHCI Host Controller
[ 2.660093] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
11 months 3 weeks ago #337990 by clayton2ndtry
Dell Optiplex 960. /proc/cpuinfo
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Parallel port. The md5sum test passes.
I have backed up everything.
/proc/meminfo MemTotal: 3071164 kB
Are you telling me that upgrading past 2.7.15 may not work?
11 months 3 weeks ago #337993 by tommylight
Yes he is, do not upgrade unless there is something you absolutely need.
If the machine is working properly, NEVER upgrade. This is not MS windows.
I have several (roughly 10) machines using Ubuntu 8.04 and 10.04, all over 15 years old, all still working every day.
11 months 3 weeks ago #338032 by clayton2ndtry
It appears the core problem is that 2.9 requires a 64 bit processor and my antique is a 686. I guess I will be staying in the past untilll I buy a new desktop.
11 months 3 weeks ago #338036 by unknown
11 months 3 weeks ago #338037 by unknown
If you really want to upgrade, first thing I would do is boot the latest Linuxcnc image, run latency-histogram --nobase if you get under 100ns latency, rather than upgrade your PC get a mesa 7i92, it will plug into your existing breakout board and start making chips.
Time to create page: 0.064 seconds
