User name rpi-first-boot-wizard
11 months 16 hours ago #339567 by jaro_p
After a few years I pulled out my RPi4 and Mesa 7c81 from the drawer again. I tried to install raspi os 2.9.7... And that's it. After a while of inactivity my screen locked and I was done. I searched the "entire" web, but I couldn't find the password for that awesome username anywhere.
11 months 15 hours ago #339568 by unknown
As per instructions you either set the password or username prior to writing the imagery via RPi-imager or you set the user name and password via the first boot wizard, exactly the same process as you would go through with a stock raspios image.
The change in the way the image was built was to make it easier for a user to setup thier wifi and locale, and to allow the user to select a username and password to their liking.
11 months 15 hours ago #339571 by jaro_p
Thanks for the answer, but that is not possible. Option Customisation is greyed out and inactive in RPi Imager version 2.0. ISO image was :image_2025-11-10-raspios-lcnc-2.9.7-6-trixie-arm64.zip
11 months 15 hours ago #339573 by unknown
As I said it can also be set via the first book wizard, but I'm at a loss as why RPi image doesn't allow you to set the customisations, all the while I have been building the various version that has never happened, I had to download the latest version on my Debian Dev machine.
The following user(s) said Thank You: jaro_p
11 months 14 hours ago #339574 by jaro_p
So after booting without a password it is also not possible to change anything. But I will try an older version of Imager. Otherwise it offers an update to the new version quite aggressively.
11 months 14 hours ago #339577 by jaro_p
With Imager version 1.9 it's ok.
Can I also ask what is the replacement for mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --fallback --write.
I found:
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_rpspi
for reading (readhmid).
Or should I ask in a new forum?
Time to create page: 0.083 seconds
