User name rpi-first-boot-wizard
  • jaro_p
  • jaro_p's Avatar Topic Author
  • Senior Member
  • Senior Member
01 Dec 2025 10:38 #339567 by jaro_p
User name rpi-first-boot-wizard was created by jaro_p
After a few years I pulled out my RPi4 and Mesa 7c81 from the drawer again. I tried to install raspi os 2.9.7... And that's it. After a while of inactivity my screen locked and I was done. I searched the "entire" web, but I couldn't find the password for that awesome username anywhere.
01 Dec 2025 10:42 #339568 by unknown
Replied by unknown on topic User name rpi-first-boot-wizard
As per instructions you either set the password or username prior to writing the imagery via RPi-imager or you set the user name and password via the first boot wizard, exactly the same process as you would go through with a stock raspios image.
The change in the way the image was built was to make it easier for a user to setup thier wifi and locale, and to allow the user to select a username and password to their liking.
  • jaro_p
  • Senior Member
  • Senior Member
01 Dec 2025 11:15 #339571 by jaro_p
Replied by jaro_p on topic User name rpi-first-boot-wizard
Thanks for the answer, but that is not possible. Option Customisation is greyed out and inactive in RPi Imager version 2.0. ISO image was :image_2025-11-10-raspios-lcnc-2.9.7-6-trixie-arm64.zip
01 Dec 2025 11:25 #339573 by unknown
As I said it can also be set via the first book wizard, but I'm at a loss as why RPi image doesn't allow you to set the customisations, all the while I have been building the various version that has never happened, I had to download the latest version on my Debian Dev machine.
The following user(s) said Thank You: jaro_p
  • jaro_p
  • Senior Member
  • Senior Member
01 Dec 2025 11:40 #339574 by jaro_p
So after booting without a password it is also not possible to change anything. But I will try an older version of Imager. Otherwise it offers an update to the new version quite aggressively.
  • jaro_p
  • Senior Member
  • Senior Member
01 Dec 2025 12:01 #339577 by jaro_p
With Imager version 1.9 it's ok.
Can I also ask what is the replacement for mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --fallback --write.
I found:
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_rpspi
for reading (readhmid).
Or should I ask in a new forum?
01 Dec 2025 12:07 #339578 by unknown
After looking at the arm64 Trixie repo it appears there are no packages available for mesaflash.
One option would to be build from source.
Or to manually download the bookworm version and install that.
As it is almost 12:00 am I fear I may not be able to respond in a timely manner.
01 Dec 2025 12:07 #339579 by tommylight
Replied by tommylight on topic User name rpi-first-boot-wizard
Normally this is what is needed to read Mesa boards:
mesaflash --device 5i25 --readhmid
but for SPI i would guess
mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
should work, and it should be safe to try.
If you do have more questions about Mesa boards, use the "driver boards" section of the forum.
  • jaro_p
  • Senior Member
  • Senior Member
01 Dec 2025 12:09 #339580 by jaro_p
Ok Thank you
  • jaro_p
  • Senior Member
  • Senior Member
01 Dec 2025 14:48 #339592 by jaro_p
Unfortunately, in trixie image_2025-11-10-raspios-lcnc-2.9.7-6-trixie-arm64.zip the command mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid doesn't work. No 7c81 board found.
Time to create page: 0.284 seconds
