Parallel Port - how to invert PWM value
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
3 months 2 weeks ago #347838 by rodw
I decided to build a parallel port LinuxCNC config cos I'd never done one before. All went very easily after firing up stepconf which got motors moving straight out of the box.
But now I got problems with the PWM to control the spindle because the volts were running the wrong way eg 24000 rpm = 0 volts and 0 rpm = 10 volts. I thought it would be easy to invert the signal but to  no avail.
I tried to adjust with a sum2 component so -24000 + Commanded RPM = - desired RPM. This turned out to be a dry gully too.
I figured if I had to  convert it to an absolute number I could do that but halshow promptly showed me that -24000 + 12000 = 0
I got rid of the negative and used a gain of -1 and I still got the same wrong answer...
So what is the trick to invert the PWM value?
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
3 months 2 weeks ago #347839 by rodw
Replied by rodw on topic Parallel Port - how to invert PWM value
Hmm, this might work
parport.<p>.pin-<n>-out-invert
3 months 2 weeks ago #347844 by tommylight
Replied by tommylight on topic Parallel Port - how to invert PWM value
Some examples of PWM stuff:
loadrt pwmgen output_type=1 addf pwmgen.make-pulses base-thread addf pwmgen.update servo-thread net dout-00 <= pwmgen.0.pwm setp pwmgen.0.pwm-freq 1000.0 setp pwmgen.0.scale 6.0 setp pwmgen.0.offset 0.2 setp pwmgen.0.dither-pwm true net dout-00 => parport.0.pin-02-out
Probably more there, but usually all you need is frequency and scale, sometimes also offset.
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
3 months 2 weeks ago #347850 by rodw
I answered my own question by reading the docs!
setp parport.0.pin-01-out-invert 1
Is exactly what I needed, I went looking for -not pins with no joy and never thought to look at parameters
3 months 2 weeks ago #347852 by tommylight
That is why i did not mention it, as that is exactly what you needed.
Welcome to the parport club, i bought 3 old PC's with parallel ports (a Pentium 4 and two of Core 2) for 40 euro about 5 days back, and no matter how much fanfare goes on here from time to time about it being obsolete, i still love it as it works perfectly...for nearly 20 years without a single hiccup ever.
And also keep a stock of 2-4 at all times in the shop, so now should be 6...as one went off yesterday to it's new work place.
3 months 1 week ago #347877 by PCW
Replied by PCW on topic Parallel Port - how to invert PWM value
"-not" works for inputs, but not outputs
(without some fairly micky-mouse logic)
3 months 1 week ago - 3 months 1 week ago #347887 by Todd Zuercher
Replied by Todd Zuercher on topic Parallel Port - how to invert PWM value
Wouldn't the proper way to invert a PWM be to use a negative value for the PWM scale? (setp pwmgen.N.scale = negative value)
Last edit: 3 months 1 week ago by Todd Zuercher.
3 months 1 week ago #347891 by PCW
If you had signed PWM hardware and you got minus full scale
instead of full scale with a full scale positive PWM value, then  yes,
inverting the PWM scale would fix the problem.
For unsigned PWM when 0% duty cycle PWM gives you full scale output
and 100% duty cycle gives you 0% output, you would need to digitally invert
the PWM pin (and this is the situation here AFAICT)
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
3 months 1 week ago - 3 months 1 week ago #347907 by rodw
I thought this too. But I was wrong!
Peter has it right. You need to use the parameter for the pin to invert it
Last edit: 3 months 1 week ago by rodw.
Time to create page: 0.059 seconds
