- Thank you received: 25
MesaCT and 7i76eu Issues with generated configuration
- LearningLinuxCNC
- Topic Author
11 months 3 days ago #339710
by LearningLinuxCNC
MesaCT and 7i76eu Issues with generated configuration was created by LearningLinuxCNC
It could be that I am an imbecile. However when I used MesaCT as installed per the instructions here using apt
gnipsel.com/linuxcnc/mesact/install.html#install-with-apt
. I did not get an anywhere near working configuration out of the tool. The stepper configurations were very incomplete. The feedback loop was not closed in fact the PID output was not even sent to the mesa stepper driver.
I will post up my configuration files from the output shortly.
- LearningLinuxCNC
- Topic Author
11 months 2 days ago #339748
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic MesaCT and 7i76eu Issues with generated configuration
Here is a generated HAL file X axis configuration.
This is what I had to change it to in order to make it work properly.
# Axis: X Joint: 0 Output: 2
# PID Setup
setp pid.x.Pgain [JOINT_0](P)
setp pid.x.Igain [JOINT_0](I)
setp pid.x.Dgain [JOINT_0](D)
setp pid.x.bias [JOINT_0](BIAS)
setp pid.x.FF0 [JOINT_0](FF0)
setp pid.x.FF1 [JOINT_0](FF1)
setp pid.x.FF2 [JOINT_0](FF2)
setp pid.x.deadband [JOINT_0](DEADBAND)
setp pid.x.maxoutput [JOINT_0](MAX_OUTPUT)
setp pid.x.error-previous-target True
# joint-0 enable chain
net joint-0-index-enable <=> pid.x.index-enable
net joint-0-index-enable <=> joint.0.index-enable
net joint-0-enable <= joint.0.amp-enable-out
net joint-0-enable => pid.x.enable
# position command and feedback
net joint-0-pos-cmd <= joint.0.motor-pos-cmd
net joint-0-pos-cmd => pid.x.command
net joint-0-pos-fb <= hm2_[MESA](BOARD).0.stepgen.00.position-fb
net joint-0-pos-fb => joint.0.motor-pos-fb
net joint-0-pos-fb => pid.x.feedback
# PID Output
net joint.0.output <= pid.x.output
# Axis: Z Joint: 1 Output: 3
# PID Setup
setp pid.x.maxerror 0.0005
net joint-0-enable => hm2_[MESA](BOARD).0.stepgen.02.enable
net joint-0-vel-cmd <= joint.0.vel-cmd
net joint-0-pos-fb <= hm2_[MESA](BOARD).0.stepgen.02.position-fb
# PID Output
net joint.0.output => hm2_[MESA](BOARD).0.stepgen.02.velocity-cmd
- Thank you received: 3485
11 months 2 days ago #339763
Replied by PCW on topic MesaCT and 7i76eu Issues with generated configuration
You might post a link to this thread on the MesaCT topic
- JT
- Thank you received: 516
10 months 4 weeks ago - 10 months 4 weeks ago #339909
by JT
Replied by JT on topic MesaCT and 7i76eu Issues with generated configuration
Can you attach your ini file?
Did you skip Drive 0 and Drive 1?
JT
JT
Last edit: 10 months 4 weeks ago by JT.
Time to create page: 0.063 seconds
