Thank you very much, Hakan.
You are right to suspect it's an issue with the drive, and I am trying to get as much information as possible from the supplier. It's been a little tricky because the salesperson has to relay all the info to the VFD engineers in Chinese. The lesson for next time is to make sure the drive is CiA402 compatible.
It's hard to judge from the test results whether the 880 after start and stop makes a difference. Either way, I continue to experience inconsistent and prolonged delays.
Regarding the 6.05 section, I was trying to decode the decimal values of the control and status words used in Halrun and TwinCAT. I have now updated the PDO
spreadsheet
to include the decoding based on the bit tables in the manuals.
Any ideas what I should try next, if I don't have any luck with the VFD manufacturer?
