Reload gcode
  • MaHa
  • Topic Author
  • Platinum Member
  • Platinum Member
9 months 1 week ago #341898 by MaHa
Reload gcode was created by MaHa
After a break, when running my machine, i can load a gcode file. But trying reload or edit crashes with following error:
Traceback (most recent call last):   File "/usr/lib/python3/dist-packages/libflexgui/actions.py", line 147, in action_reload     if gcode_file:        ^^^^^^^^^^ NameError: name 'gcode_file' is not defined. Did you mean: 'nc_code_file'? /usr/bin/linuxcnc: Zeile 977: 11062 Abgebrochen             $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS Shutting down and cleaning up LinuxCNC...
9 months 1 week ago #341903 by JT
Replied by JT on topic Reload gcode
Sorry, I must have got distracted when changing the variable name and didn't finish changing every occurrence. The bug has been squashed.
JT
The following user(s) said Thank You: tommylight, 0x2102, MaHa
Moderators: JT
Time to create page: 0.054 seconds
