- Thank you received: 817
(Solved) FlexGUI - Multiple spindles?
- spumco
- Topic Author
6 months 3 weeks ago #345627
by spumco
(Solved) FlexGUI - Multiple spindles? was created by spumco
Starting to set up spindle status displays in Flex and ran in to a snag.
The documentation isn't explicit about how to reference multiple spindles, but I'm guessing the "0" in dynamic property like spindle_speed_0_lb is for [SPINDLE_0].
Problem 1 - spindle_actual_speed_lb doesn't reference a particular spindle. Oversight in documentation, or was this not set up for multiple spindle encoders? Document also has this note:
So I'm not sure if I should use the spindle_actual_speed_lb, or just set up a HAL float label.
Problem 2 - document indicates Flex looks for [SPINDLE_0]:
What about other spindles? I've got three spindles on my lathe (main, sub, live-tool), and (theoretically) all three could be running at the same time.
I can probably muddle through using HAL labels and so forth, but was wondering if there's a built-in set of spindle connections I'm just not seeing.
Thx
NoteTo get actual spindle speed you need to connect the spindle encoder to an encoder component and use the encoder.N.velocity-rpm float out connected to a HAL float label.
On start-up, Flex will check for the following items in the [SPINDLE_0] section of the .ini file
Thx
- Thank you received: 2620
6 months 2 weeks ago #345652
Replied by andypugh on topic (Solved) FlexGUI - Multiple spindles?
Spindles are typically controlled through the NML interface by the GUIs, so if the GUI doesn't support multiple spindles you might have to use MDI to turn on and off the auxilliary spindles.
THat said, flexgui is mane to be flexible, so maybe there is suopport?
I haven't used it yet.
- spumco
- Topic Author
6 months 2 weeks ago #345662
by spumco
All machine functions are already handled with hardware controls; I just want displays for all three spindles. The only on-screen control which could cause machine movement of any type will be an MDI 'run' button.
I'm guessing FlexGUI is new enough that @JT hasn't had anyone bugging him about outlier configurations much.
Replied by spumco on topic (Solved) FlexGUI - Multiple spindles?
Thanks Andy. I'm trying it out for the first time now.Spindles are typically controlled through the NML interface by the GUIs, so if the GUI doesn't support multiple spindles you might have to use MDI to turn on and off the auxilliary spindles.
- spumco
- Topic Author
6 months 2 weeks ago #345793
by spumco
Mods - please mark as 'solved'
Looks like JT updated FlexGUI for multiple spindles on GH a few hours ago.
Can't wait to update and have a go at it!
The following user(s) said Thank You: tommylight, JT
6 months 2 weeks ago #345794
Replied by tommylight on topic (Solved) FlexGUI - Multiple spindles?
Done, thank you.Mods - please mark as 'solved'
- JT
- Thank you received: 516
6 months 2 weeks ago - 6 months 2 weeks ago #345837
by JT
Replied by JT on topic (Solved) FlexGUI - Multiple spindles?
Just completed the multiple spindle update to Flex GUI. It now fully supports all 8 spindles.
JT
JT
Last edit: 6 months 2 weeks ago by JT.
The following user(s) said Thank You: tommylight, spumco
- spumco
- Topic Author
6 months 2 weeks ago #345872
by spumco
@JT -
Thank you for the update and new pins. I pulled the latest deb and Flex is recognizing the additional spindle connections I put in my test GUI.
This doesn't affect me directly - I have no GUI spindle controls, just displays - but are there similar multi-spindle control pins? I didn't see any update in the docs about those changing.
- JT
6 months 2 weeks ago - 6 months 2 weeks ago #345883
by JT
Yes, Flex has full manual spindle controls for all 8 spindles. I'm working on updating the documents.
Just to prevent any search engine from finding incorrect information I deleted the posts with the incorrect information.
JT
JT
Moderators: JT
Time to create page: 0.070 seconds
