Z-axis doesn’t move
2 weeks 6 days ago #350208 by yaska
Z-axis doesn’t move was created by yaska
I’ve had problems with my lathe after running ‘reference’ in Flex GUI.
When both axes are  homed, I can jog the X-axis without any problems.
But the Z-axis doesn’t move. If I run ‘unhome’ on the X or Z, I can jog the Z-axis.
I switched to Probe Basic and it works as intended with the same INI file
no problems with jogging once the axes are  homed.
I checked with HalShow, and the difference between Flex GUI and PB was that the telop
function worked on both axes in PB but only on the X-axis in Flex GUI.
In Flex GUI, the X-axis is 0 and the Z-axis is 1. When the axes are not at home, jogging works normally. Where should I look for the fault?
2 weeks 3 days ago #350262 by tommylight
Replied by tommylight on topic Z-axis doesn’t move
Attach the hal and ini files here so we can have a look.
2 weeks 3 days ago #350287 by yaska
Replied by yaska on topic Z-axis doesn’t move
Here are the files you asked for
On a lathe, the Z-axis is No. 2, and on a mill, it’s No. 3. I think that’s where the problem comes from—previously, I had to have two Z- and two Z+ buttons; on one pair, I used jog_1_pb,
and on the other, I used jog_2_pb, which I used when the axes were homed, and it worked. When the axes weren’t homed, I had to use jog_pb_1 to move the axis.
So why does it work normally in Probe Basic but not in Flex GUI?
2 weeks 11 hours ago #350315 by yaska
As I mentioned earlier, in FlexGui, the Z-axis = 2 on a milling machine, and on the lathe, Z = 1. If I change Z to Y in the ini file to the following:
KINEMATICS = trivkins coordinates=xy
COORDINATES = X Y
[AXIS_Y]
Then I can jog the Z-axis after homing, just as it’s supposed to work,
but of course the lathe won’t run because it requires XZ.
So now I hope you’ll make the necessary changes so it works correctly.
2 weeks 8 hours ago #350323 by MaHa
Replied by MaHa on topic Z-axis doesn’t move
If you have copied flex examples, here is a lathe starter
linuxcnc/configs/flex_examples/starters/Lathe/
There is:
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZ
[TRAJ]
COORDINATES =  X Z
[AXIS_X]
[JOINT_0]
[AXIS_Z]
[JOINT_1]
and use qpushbuttons  jog_plus_pb_0, jog_minus_pb_0, jog_plus_pb_1, jog_minus_pb_1
Moderators: JT
Time to create page: 0.190 seconds
