Z-axis doesn’t move
2 weeks 3 hours ago #350324 by yaska
Replied by yaska on topic Z-axis doesn’t move
 Here are the files again
File Name: weiler_cnc...18-3.ini
File Size:5.45 KB
File Name: main_2026-10-18-3.hal
File Size:11.83 KB
2 weeks 3 hours ago #350325 by yaska
You probably didn't read the whole thread—this is what it's all about
I’ve had problems with my lathe after running ‘reference’ in Flex GUI.
When both axes are  homed, I can jog the X-axis without any problems.
But the Z-axis doesn’t move. If I run ‘unhome’ on the X or Z, I can jog the Z-axis.
I switched to Probe Basic and it works as intended with the same INI file
no problems with jogging once the axes are  homed.
I checked with HalShow, and the difference between Flex GUI and PB was that the telop
function worked on both axes in PB but only on the X-axis in Flex GUI.
In Flex GUI, the X-axis is 0 and the Z-axis is 1. When the axes are not at home, jogging works normally. Where should I look for the fault?
On a lathe, the Z-axis is No. 2, and on a mill, it’s No. 3. I think that’s where the problem comes from—previously, I had to have two Z- and two Z+ buttons; on one pair, I used jog_1_pb,
and on the other, I used jog_2_pb, which I used when the axes were homed, and it worked. When the axes weren’t homed, I had to use jog_pb_1 to move the axis.
So why does it work normally in Probe Basic but not in Flex GUI?
As I mentioned earlier, in FlexGui, the Z-axis = 2 on a milling machine, and on the lathe, Z = 1. If I change Z to Y in the ini file to the following:
KINEMATICS = trivkins coordinates=xy
COORDINATES = X Y
[AXIS_Y]
Then I can jog the Z-axis after homing, just as it’s supposed to work,
but of course the lathe won’t run because it requires XZ.
So now I hope you’ll make the necessary changes so it works correctly.
Moderators: JT
Time to create page: 0.048 seconds
