G64 P- Q- naive cam tolerance setting
19 Apr 2012 06:07 #19371 by subtractive
G64 P- Q- naive cam tolerance setting was created by subtractive
Hope this isn't a daft question with an obvious answer, but I'm not sure what the Q setting units are in G64 P- Q- .
To quote the LinuxCNC User Guide:-
G64 P- Q- it turns on the "naive cam detector"; when there are a series of linear XYZ feed moves at
the same feed rate that are less than Q- away from being collinear, they are collapsed into a single
linear move.
'less than Q- away from being collinear' ? Would that be an angle or a linear distance?
:unsure:
19 Apr 2012 07:47 #19373 by andypugh
Replied by andypugh on topic Re:G64 P- Q- naive cam tolerance setting
subtractive wrote:
'less than Q- away from being collinear' ? Would that be an angle or a linear distance?:
Linear AFAIK.
Time to create page: 0.223 seconds
