New syntax highlighting for gedit
- FernV
- Thank you received: 124
21 Apr 2016 04:37 #73674
by FernV
New syntax highlighting for gedit was created by FernV
For those of you that prefer using gedit, I wrote a new HL file for you.
Just copy ngc.lang.txt file to either (REMOVE THE .txt EXTENSION)
/usr/share/gtksourceview-3.0/language-specs/
or
~/.local/share/gtksourceview-3.0/language-specs/ (you can also use 2.0 instead)
and GCode.xml (colors) in
/usr/share/gtksourceview-3.0/styles/
or
~/.local/share/gtksourceview-3.0/styles/
then restart gedit, open a ngc file and select GCode color scheme
here what it looks like
If you do not like the colors I selected, try to find a scheme you like or edit GCode.xml by inspecting ngc.lang to see how colors are mapped
Best regards
Fernand
or
or
Best regards
Fernand
The following user(s) said Thank You: BigJohnT, andypugh, chucktilbury, Amedee, webmanoffesto, Studi
- BigJohnT
- Thank you received: 994
22 Apr 2016 22:19 #73731
by BigJohnT
Replied by BigJohnT on topic New syntax highlighting for gedit
I'm using Gedit on LinuxMint 17.3 but don't see the directories you mention.
JT
JT
- Amedee
- Thank you received: 13
23 Apr 2016 08:27 #73738
by Amedee
Replied by Amedee on topic New syntax highlighting for gedit
I don't have Mint, but i believe it is shipped with GTK2 so you need to look for /usr/share/gtksourceview-2.0/ directory
- BigJohnT
23 Apr 2016 11:32 - 23 Apr 2016 11:51 #73744
by BigJohnT
Last edit: 23 Apr 2016 11:51 by BigJohnT.
- Amedee
23 Apr 2016 13:01 - 23 Apr 2016 13:02 #73749
by Amedee
Last edit: 23 Apr 2016 13:02 by Amedee.
- BigJohnT
23 Apr 2016 14:26 #73757
by BigJohnT
Now that looks much better and I even like it!
JT
JT
- webmanoffesto
19 May 2016 17:07 #74856
by webmanoffesto
Replied by webmanoffesto on topic New syntax highlighting for gedit
It's working great for me. Thank you.
- Studi
07 Nov 2020 10:01 #188582
by Studi
Replied by Studi on topic New syntax highlighting for gedit
hello FERN
got it installed. Works as promised.
Thank you so much! :Lachen:
Tip: For Windows users
the path to the directories is called here:
Storage location of the program then \ share \ gtksourceview-2.0 \ language-specs
for the file: ngc.lang
and
Storage location of the program then \ share \ gtksourceview-2.0 \ styles for the file: GCode.xml
and
The following user(s) said Thank You: rootboy
- jherzvt
09 Jan 2025 22:10 #318580
by jherzvt
Replied by jherzvt on topic New syntax highlighting for gedit
Thank you so much to FernV for this. It is just what I was looking for and the old links from the LinuxCNC manual were dead.
Two comments though, from this extremely inexpert user.
The first is that in my version of UbuntuStudio 24.04 with Kde both the language-specs and the styles directories are in /usr/share/libgedit-gtksourceview-300/
The second is that after I put Gcode.xml into the styles directory, highlighting did not work until I renamed Gcode.xml to ngc.xml
Now it works great!
thanks, Jonathan
Now it works great!
thanks, Jonathan
The following user(s) said Thank You: tommylight, Cant do this anymore bye all
Time to create page: 0.133 seconds
