Keyboard re-mapping (key binding)
- ioiotutu
is it possible remap some commands keys?
I need to swap arrow-left/arrow-right (X moving) with arrow-up/arrow-dn (Y moving). Is there a config file for this?
Thanks,
Michele
- BigJohnT
- Thank you received: 994
I think so.
linuxcnc.org/docs/html/gui_axis.html#r1_11_4
Though I don't know if that allows you to re-map keys which are already allocated. I also have no idea what the correct syntax is, but you can probably just copy the program lines from inside Axis.
- ioiotutu
when i'm in front of the machine i see Y axis: moving right + direction, moving left - direction. X axis moving to me + direction and far to me - direction.
Home position is right - up (far to me).
I hope you understand my bad english!
So when push arrow key i need:
arrow-right -> Y +
arrow-left -> Y -
arrow-up -> X-
arrow-down -> X+
where can i find axis.py?
- BigJohnT
Unless you have some strange machine... do you have a photo of it?
- ioiotutu
- ioiotutu
- BigJohnT
Otherwise you would have to modify axis.py to change the key bindings. I scanned through the 3400 lines of code and nothing jumped out at me.
Is this thing on?
www.linuxcnc.org/component/option,com_ku.../lang,english/#14678
- BigJohnT
