[Solved] ModBus server comp error: expecte
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 May 2016 10:33 - 05 May 2016 17:56 #74213 by bkt
In order to try and test my new component for make a usercomp with modbus server i get these error at first compiling ....
halcompile --compile --userspace  k1MbServer.comp
gcc -Os -g -I. -I/usr/realtime-2.6.32-122-rtai/include -I. -I/usr/realtime-2.6.32-122-rtai/include -D_FORTIFY_SOURCE=0 -mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os  -o k1MbServer /tmp/tmp_VFDTq/k1MbServer.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
In file included from /usr/local/include/modbus/modbus.h:283,
                 from k1MbServer.comp:125:
/usr/local/include/modbus/modbus-rtu.h:35: error: expected ‘)’ before ‘->’ token
k1MbServer.comp: In function ‘user_mainloop’:
k1MbServer.comp:264: warning: ‘return’ with a value, in function returning void
make: *** [k1MbServer] Error 1
I add my file (my idea is share it ..)
I've not solution for these error ..... the component is not tested yet ..... and not well structured...
giorgio
File Name: k1MbServer.comp
File Size:14 KB
Last edit: 05 May 2016 17:56 by bkt.
  • bkt
  • Platinum Member
  • Platinum Member
05 May 2016 17:55 - 05 May 2016 17:57 #74281 by bkt
in the doc: option_link_args " ..." for add link etc etc .....
instead these command I wrote:
option_compile_args "-lm etc etc ...." ... in the old discussion with arcEye & andyPugh i see a link to parser.c file of halcompile ..... inside the file I found these option ....
Now all work fine!! (I add my definitive comp after hard test!..)
Regards
Giorgio
Last edit: 05 May 2016 17:57 by bkt.
Time to create page: 0.092 seconds
