more than 16 time a components with "names ="
- Curt007
14 Aug 2016 13:42 #78738
by Curt007
more than 16 time a components with "names =" was created by Curt007
Hello friends.
I need help about HAL twopass.
I try to clean up my hal files.
I try to use HAL TwoPass and I encounter the following problem:
I use 20 times the AND2 component, and in mode "loadrt names= (with 20 names)" (instead of loadrt count=20") is denied me.
I saw in the dmesg: names: can only take 16 arguments.
is there a way to load more than 16 time a components with "names =" ?
Someone could help me?
Thanks a lot.
Curt
Thanks a lot.
Curt
15 Aug 2016 12:21 #78796
github.com/LinuxCNC/linuxcnc/blob/master...ls/halcompile.g#L476
Lines 476 and 479
As halcompile is written in C you should be able to change halcompile.py and then re-compile and install and2.comp
But...
I suspect that if you need 20x and2 components then you might want to consider using something else, such as LUT5 or a custom component. why do you need so many of them?
Replied by andypugh on topic more than 16 time a components with "names ="
Lines 476 and 479
But...
- Curt007
15 Aug 2016 21:01 #78810
by Curt007
Replied by Curt007 on topic more than 16 time a components with "names ="
Thanks a lot Andy !
I will study this solution.
I think this is the most clean and nice.
Otherwise, maybe, I can also add with COMP some other and2, by and2A and2B..named.
This will be easier for me.
My problem is that I use some only 2 inputs and's in different parts of hal.
I can not replace them with kind which haves more inputs (like logic).
15 Aug 2016 21:22 #78811
If they do different things, then you can't combine them, but if they are just in different files, then you can. There is no reason that all inputs to a logic-AND have to be connected in the same file.
- Nico2017
- Thank you received: 26
31 Jan 2019 05:49 #125372
by Nico2017
Replied by Nico2017 on topic more than 16 time a components with "names ="
should this limitation of 16 items when using the loadrt with names with Two passes been overcome or taken into account into the latest version? Running the 2.8 version, I am still facing this issue.
I was in the same case and had to switch all the items with more than 16 elements to the count= convention. This makes the TWO PASSES feature less usefull and powerfull. I thought that the idea of TWO PASSES was not be limited by the number defined in count that you have to "painfully" update everytime you add a new item on a component. Would be nice if this limitation was no longer existing with the TWO PASSES.
Thank you,
Nicolas
Thank you,
Nicolas
The following user(s) said Thank You: Mike_Eitel
- dgarrett
- Thank you received: 297
01 Feb 2019 15:03 #125474
by dgarrett
Replied by dgarrett on topic more than 16 time a components with "names ="
Added commit (master branch) to provide a command line
option to halcompile (--names=) to alter the default
limit (16) on the number of 'names' instances:
github.com/LinuxCNC/linuxcnc/commit/c0cc...b384328cdc1c0499645c
__________________________________________________________
For a standard component in a RIP build, you can
reinstall a single component using the new --names= option:
(Note, for a RIP build, one can change the limits for
*all* halcompile components by changing the value of
MAX_NAMES in src/hal/utils/halcompile.g and rebuilding.
You will have to deal with a file conflict for halcompile.g
when rebuilding after updates to the source tree).
To alter a standard component when using a master branch
deb install (from the buildbot):
1) the (updated) linuxcnc-dev package is required to
make halcompile available.
2) make a local copy the source for any standard component
from the github source tree:
github.com/LinuxCNC/linuxcnc/tree/master/src/hal/components
3) Select the required .comp file, find the link for the raw file
and download the raw .comp file
4) Install the local .comp file using:
halcompile --names=value --install ...
Example for the and2 component with name= limit of 22:
Note: When using a *local* copy of a standard component, the
installed component will be *overwritten* when an upgraded
deb for LinuxCNC is installed so the steps to rehalcompile
must be repeated. The same problem will occur when
rebuilding a RIP build.
For this eventuality, one could rename the local copy
(example: mv and2.comp And2.comp). It is also necessary to
edit this And2.comp file to change the component name inside
the file from and2 to And2.
$ source scripts/rip-environment
$ cd src/hal/components
$ # example: allow up to 22 'name' instances:
$ halcompile --names=22 --install somename.comp(Note, for a RIP build, one can change the limits for
$ mkdir ~/local_comp_files
$ cd ~/local_comp_files
$ # get the raw and2.comp file:
$ wget https://raw.githubusercontent.com/LinuxCNC/linuxcnc/master/src/hal/components/and2.comp
$ # halcompile with 'names' limit of 22:
$ sudo halcompile --names=22 --install and2.comp
$ # test:
$ halrun
$ loadrt and2 names=a,b,c,...__________________________________________________________
- Mike_Eitel
- Thank you received: 183
01 Feb 2019 15:24 #125477
by Mike_Eitel
Replied by Mike_Eitel on topic more than 16 time a components with "names ="
THX
For my understanding:
I have to run that every time after a normal synaptic upgrade run.
Correct?
Mike
Correct?
Mike
Time to create page: 0.090 seconds
