increases / decreases spindle speed
- dinkata
24 Sep 2016 05:15 #80844
by dinkata
increases / decreases spindle speed was created by dinkata
Configuration 5i25 + 7i77. The turnover of the spindle is adjusted by +/- 10V.
I want to use with external buttons:
halui.spindle.increase (bit, in) - increases spindle speed
halui.spindle.decrease (bit, in) - decreases spindle speed
in hal:but change fixed at 100 rev / min, for example : I have
M3 S200 , increase adds 100 to each press button , and I want 20 or 50.
How to set up a step change from 100 to 50 or 20 or 30 ?
in hal:
# --- SPNINCR ---
net Spnincr <= hm2_5i25.0.gpio.026.in_not => halui.spindle.increase
# --- SPNDECR ---
net Spndecr <= hm2_5i25.0.gpio.027.in_not => halui.spindle.decreaseM3 S200 , increase adds 100 to each press button , and I want 20 or 50.
- BigJohnT
- Thank you received: 994
24 Sep 2016 18:26 #80861
by BigJohnT
Replied by BigJohnT on topic increases / decreases spindle speed
What version of LinuxCNC are you using?
JT
JT
- Thank you received: 2173
24 Sep 2016 19:02 #80864
Replied by cmorley on topic increases / decreases spindle speed
It is not configurable - other then changing the source code.
from command.c:
Chris M
from command.c:
case EMCMOT_SPINDLE_INCREASE:
rtapi_print_msg(RTAPI_MSG_DBG, "SPINDLE_INCREASE");
if (emcmotStatus->spindle.speed > 0) {
emcmotStatus->spindle.speed += 100; //FIXME - make the step a HAL parameter
} else if (emcmotStatus->spindle.speed < 0) {
emcmotStatus->spindle.speed -= 100;
break;
case EMCMOT_SPINDLE_DECREASE:
rtapi_print_msg(RTAPI_MSG_DBG, "SPINDLE_DECREASE");
if (emcmotStatus->spindle.speed > 100) {
emcmotStatus->spindle.speed -= 100; //FIXME - make the step a HAL parameter
} else if (emcmotStatus->spindle.speed < -100) {
break;Chris M
The following user(s) said Thank You: dinkata
- dinkata
25 Sep 2016 05:20 #80875
by dinkata
DISPLAY=gmoccapy
Replied by dinkata on topic increases / decreases spindle speed
LinuxCNC 2.7.7What version of LinuxCNC are you using?
DISPLAY=gmoccapy
- dinkata
25 Sep 2016 05:25 #80876
by dinkata
Chris M wrote :
How to edit ?
Where is this ?from command.c:
How to edit ?
25 Sep 2016 07:41 #80880
src/emc/motion/command.c
Most users don't compile the source code, they use the binaries.
You would need to get the source code, change the code and recompile.
this is an old explanation of how to build from source:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal..._or_8_04_from_source
hopefully someone else could suggest a more current guide.
Chris M
Chris M
- dinkata
25 Sep 2016 07:54 #80881
by dinkata
www.linuxcnc.org/linuxcnc-2.7-wheezy.iso
Can I do something there ?
I have installedsrc/emc/motion/command.c
- dinkata
25 Sep 2016 10:07 - 25 Sep 2016 10:24 #80891
by dinkata
Am I wrong or is it a bug .
I use button halui.spindle-override.increase , halui.spindle-override.decrease
Spindle speed blink
Spindle speed blink
Last edit: 25 Sep 2016 10:24 by dinkata.
- pippin88
- Thank you received: 51
26 Sep 2016 09:29 - 26 Sep 2016 09:30 #80924
by pippin88
Could spindle-override be used, which has a scale property?
I'm having issues with this at present in gmoccapy, but works in axis.
Replied by pippin88 on topic increases / decreases spindle speed
from command.c:
case EMCMOT_SPINDLE_INCREASE: rtapi_print_msg(RTAPI_MSG_DBG, "SPINDLE_INCREASE"); if (emcmotStatus->spindle.speed > 0) { emcmotStatus->spindle.speed += 100; //FIXME - make the step a HAL parameter } else if (emcmotStatus->spindle.speed < 0) { emcmotStatus->spindle.speed -= 100; } break; case EMCMOT_SPINDLE_DECREASE: rtapi_print_msg(RTAPI_MSG_DBG, "SPINDLE_DECREASE"); if (emcmotStatus->spindle.speed > 100) { emcmotStatus->spindle.speed -= 100; //FIXME - make the step a HAL parameter } else if (emcmotStatus->spindle.speed < -100) { emcmotStatus->spindle.speed += 100; } break;
Chris M
# Spindle override
#mux allows us to choose between the two values. mux2.n.out defaults to .in0 if mux2.n.sel is not called
setp mux2.0.in0 0.1
setp mux2.0.in1 0.05
net spinshift mux2.0.sel <= hm2_7i43.0.7i76.0.0.input-02 #shift white
net spinoverride halui.spindle-override.scale <= mux2.0.out
net spinup <= hm2_7i43.0.7i76.0.0.input-00 #up orange
net spindown <= hm2_7i43.0.7i76.0.0.input-01 #down blue
net spinup => halui.spindle-override.increase
net spindown => halui.spindle-override.decreaseI'm having issues with this at present in gmoccapy, but works in axis.
Last edit: 26 Sep 2016 09:30 by pippin88.
Moderators: newbynobi, HansU
Time to create page: 0.447 seconds
