my m4 Mazak lathe
- M4MazakUser
- Thank you received: 6
The company I work for "Readings Engineering" bought the m4 a year ago in working order, it had come from a "Ford engine plant selloff" and seems to have been used in the toolroom for many years as the slideways are in excellent condition. However being as it was made in 1984 the electronics were only just holding up. 6 months after getting it we replaced the spindle motor and drive with a Vacon a/c unit.
So when the main board in the control was going to cost 4k for a replacement - which may not fix the problem - I mentioned emc....
I knew of emc since I saw it on "Slashdot" many years ago. Being a Linux user I understood most of the terminology from go.
The work done by other people on this site is what really convinced me to retrofit the m4, and the fact that we ain't had much work on lately ( but it's piled up now).
So first up I found that there was a lot of excess wiring in the cabinet. The bar feeder that came with the machine (from new) had it's own control. This control was also inside the cabinet, and not used. Saved some money by using the old relays with new bases from Finder, all the 110v electrics were stripped out and 240v equivalents installed (fans, etc) -Though I'm not sure of what voltage the hydraulic solenoids run from.
having convinced the boss, I bought ...
A 17" touchscreen
A new pc in parts, gigabyte mb, Phenom 2 4x chip, fast ram, a 32mb ssd, and a printer port card.
A Mesa 5120 card and two I/o daughter cards, and a servo daughter card. I got a isio card too but couldn't get it to work.
A 5 metre USB extension cable and a hub so I can connect the touchscreen at the control to the pc in the cabinet.
I also needed several power supplies for things in various places. For example, +/- 12v for the servo drives. This was supplied previously by the old control.
hurdles...
I couldn't install emc on the new computer, -the onboard LAN card needed to be disabled as it wasn't supported.
Mmmmmm.
I found that my "Vacon spindle drive didn't accept pwm, so, give it a voltage eh, but couldn't do so as the servo thread is running at 100000000 or whatever . - so I found that there was a Modbus card for the NXS spindle drive...... After another day of reading,and then enabling debug messages for modbus. I found a site that explained the error codes. - "Simply modbus"
My current problem is that I can't do threading as the spindle encoders Z channel isn't working, but !
I've found a 24v proximity sensor on the z axis that isn't used, I've hooked it to a tag on the spindle to get a once per rev signal, but! I can't send this directly to the encoder channel on the daughter card as it is 24v not 5v, but! Finder sell a 24v transistor relay (0.2ms on 0.6ms off) so I can run it thru that and back into the Mesa servo daughter card as a 5v signal.
I just got that tclgui pgm, for macro cycles and it is cool, I'm sure that after 6 more weeks of use and thoughtful configuration most people in the shop will be able to use it.
So I figure that 3weeks for the full conversion -it can now do paying jobs, is pretty good for one person.
And now I don't have to read up on stuff every night, I reckon I might get some posts done on this forum .
lol
Thanks for all the informative posts on this site.
I got the pinouts for the tra60 servo drives from a forum here somewhere ( thanks heaps), I
- robh
- Thank you received: 24
thanks for letting us know of a new grate retrofit
sounds like the TRA60s have same pinout as my TRA30s thanks for letting me know, it did take me many hours to trace and decode there meanings glad it helped someone else out.
will be nice to see some photos of your retrofit glad im not the only one that removed miles of unused cables from the machine
rob
- Thank you received: 4968
I don't quite understand this. Surely the PWM comes from the Mesa card, so the servo thread rate is irrelevant. PWM to analogue voltage is easily done with a resistor and capacitor. (it is slightly more complex if you need isolation and a voltage change, but not actually vastly so)
I've found a 24v proximity sensor on the z axis that isn't used, I've hooked it to a tag on the spindle to get a once per rev signal, but! I can't send this directly to the encoder channel on the daughter card as it is 24v not 5v, but! Finder sell a 24v transistor relay (0.2ms on 0.6ms off) so I can run it thru that and back into the Mesa servo daughter card as a 5v signal.I
I think I would be tempted to handle that via an optocoupler. You could almost certainly just use a couple of resistors as a potential divider, but the opto is less likely to damage anything if you get the values wrong. You would just need to connect the 24V prox to the led pins through a resistor of the right size to limit the current to the right value, and then the other side of the opto would connect to the Mesa card 5V and ground, and give you a nice safe isolated logic-level signal. I am using the HCPL2531, Datasheet here: docs-europe.origin.electrocomponents.com...0900766b807796f3.pdf . Cost is about $1
- M4MazakUser
- M4MazakUser
- M4MazakUser
- M4MazakUser
- willburrrr2003
Regards,
Will R.
- aike
What is the touchscreen model?
What about touchscreen drivers?
- M4MazakUser
also.....
recently one of the tra60 servo amps failed, so i upgraded the motors/drives to baldor components.
i find their stuff pretty good, aside from them sending the wrong parts twice, on their third attempt they sent all that i needed, and a bottle of oil, and some motor brushes??
ill post a vid, and get back to u on that config, -wasn't online much last week due to broken lathe.
