5i25 firmware install utility
03 Apr 2013 12:14 #32197
by bogie6040
5i25 firmware install utility was created by bogie6040
I have written a small shell script to automagicly create the folders and copy over the files required for the 5i25 cards.
zip file includes the latest ? files from post #21670
You should be able to download this, unzip it and in the unzipped folder double click the "5i25 UPDATE.sh" file and click "Run in Terminal"
Script will blanket copy what ever files are in the included folders (so updates are easy)
Please let me know if there is any issues / file missing / changes required.....
03 Apr 2013 12:38 #32199
Replied by cmorley on topic 5i25 firmware install utility
Thanks so much - I added it to pncconf 's pinned section
Chris M
Chris M
The following user(s) said Thank You: Fredman
24 Nov 2013 10:15 #41140
by A.butts
Replied by A.butts on topic 5i25 firmware install utility
this looks like it worked ok for me linux cnc 2.5.3 THX
12 Jan 2014 07:47 - 12 Jan 2014 18:26 #42632
by svenakela
Replied by svenakela on topic 5i25 firmware install utility
Pncconf in 2.6.0 (pre0-5117) did not work with these files, both Mesa card select boxes are now empty and disabled.
EDIT: I downloaded the zip file from cmorley's sticky and that worked.
Last edit: 12 Jan 2014 18:26 by svenakela.
Time to create page: 0.134 seconds
