X Both Limit + Home
- LS
02 Feb 2016 12:47 - 02 Feb 2016 22:58 #69430
by LS
X Both Limit + Home was created by LS
My machine uses it's limit switches for both end-points as well as homing. When I try configuring the X-Axis in pncconf, the Home config fields are grayed out. It only seems to occurs on X axis, Y & Z axis are fine. Please see attached screen captures.
Is there a bug, or have I done something incorrectly?
Using: LinuxCNC 2.7.3
Mesa 5i25 (no daughter card)
Last edit: 02 Feb 2016 22:58 by LS.
- LS
02 Feb 2016 23:00 #69470
by LS
Replied by LS on topic X Both Limit + Home
I'll try manually editing the config files.
- Thank you received: 2181
03 Feb 2016 03:10 #69479
Replied by cmorley on topic X Both Limit + Home
looks like a bug..i'll look at it thanks.
Chris M
Chris M
- LS
17 Feb 2016 23:30 #70319
by LS
Hi Chris,
Do you know if this bug had been resolved in 2.7.4?
Cheers,
Luke
Cheers,
Luke
18 Feb 2016 02:01 #70330
no it missed 2.7.4
Chris M
Chris M
- LS
19 Feb 2016 15:01 #70371
by LS
Okay no problem.
I've manually edited the config files to get it working for the moment.
Time to create page: 0.242 seconds
