Metric Lathe subroutines - G71, G72, etc etc
11 Jul 2011 15:03 - 18 May 2013 16:48 #11414 by ArcEye
Hi
I have been busily converting the template files and subs I have used for some time into ngcgui subs.
I have taken a modular, lego block, approach to this, intending that the user strings a series of subs together to build the full program.
Whilst I have titled this Metric lathe subs, the only metric setting is G21 in <start>
The subs do not make any assumptions or add any clearances etc. internally, other than those provided through the gui,
so they will work in any unit base
The main feature of these subs, is the ability to enter a finished profile path in terms of G01, G02 and G03 X, Z and R codes and the g71 / g72 routines will read it, work out deepest cuts required ( X and Z respectively), offset the start point by the required amount and then cut the profile in a decrementing series of loops until finished ( or finishing) dimensions are reached.
The main limiting factor is the tool profile.
All is explained fully in the README with the files.
You need to understand the ngcgui from a users perspective, to make the best of these routines. Please read Deweys notes.
The easiest way to use these subs, is to write a simple program which just traces the profile you want and load in Axis.
If the plot is what you want, copy it into the fields of the <path> sub(s)
The loop will start after a move to X[diameter + clearance] Z[startZ] and will return to these points after each loop,
so these need to be correctly entered in <start> and your code needs to finish at co-ordinates where this can be reached without collision.
Only 2 subs can be duplicated as new instances ( <moveto> and <toolchange> )
The cutting subs are for the most part split into roughing and finishing routines to allow a toolchange to be inserted between.
Usual caveats, not warranted fit for any purpose, check the plot and run in simulation first.
Programs based solely upon subs can be very difficult to debug or to spot potential problems easily.
Hope someone finds them useful.
(File now in later post)
Last edit: 18 May 2013 16:48 by ArcEye.
The following user(s) said Thank You: Diederik
11 Jul 2011 16:05 - 12 Jul 2011 08:28 #11420 by ArcEye
Apologies to anyone who downloaded before I posted this.
I made a zip of the wrong directory and omitted 4 crucial helper subs.
.zip file as above now contains all files, please download again.
PS
Found another gotcha
<toolchange> had commented out M6Tn sequence for running in sim and wasn't reinstated, now corrected.
Last edit: 12 Jul 2011 08:28 by ArcEye.
14 Jul 2011 11:08 #11519 by ArcEye
Testing continues on metal - working well, with one unforeseen exception in the <g71> sub
If turning a profile which incorporates a large taper, from a billet whose diameter is considerably greater than the finished diameter
( I was turning a large stub arbour on a R8 tapered shank from a 45mm diam. billet)
the built in limiting of fresh air cuts will lead to gouging when the large end of the taper gets down below the 'fresh air' limit because the taper will be considerably steeper than the finished angle.
Have removed the code from o710 helper sub and amended the g71 code to use whichever X value is larger for retraction, as the tool will be now starting well above the [diam+clearance] value.
Zip updated.
19 Nov 2012 00:36 #26764 by jlviloria
Replied by jlviloria on topic Re:Metric Lathe subroutines - G71, G72, etc etc
friend
first thanks for your responses in other threads.
Friend I have a doubt, G71 can be used for internal diameters? g71 but I need to apply for ID?
friend which is how to apply or install your subroutines to my linuxcnc?
I tried but it seems that I'm not doing well. you could guide me.
thanks.
Jorge
Colombia
19 Nov 2012 00:54 - 19 Nov 2012 00:55 #26765 by ArcEye
No the G71 - 72 routines are only for external profile cutting.
You can write your own or adapt mine, the internal taper routine will get you started, it is simply a matter of reversing the direction of the incremented cut on the X axis.
(and of course reversing the calculation logic accordingly)
You need to read up on ngcgui
JT has 3 sticky threads in this section which discuss how to
www.linuxcnc.org/index.php/english/forum...broutines-and-ngcgui
When you have read these, the README and __inifile_additions in my .zip will make sense
Last edit: 19 Nov 2012 00:55 by ArcEye.
19 Nov 2012 01:24 #26767 by jlviloria
ArcEye,
I never run a program in linuxcnc.
but I have a question. when you build a program with subroutines, and one is going to give an accurate measure, and you have to repeat a cut, can run only linuxcnc that step, without having to run the entire program.
2.5.1 Linuxcnc
in his "tool table". How do you compensate for wear of the tool?
Try installing the patch fanuc with git, but git linuxcnc not respond well.
thanks.
19 Nov 2012 17:00 #26790 by ArcEye
That may be the root of your problems, it must be hard to understand something as an intellectual entity without actually using it.
With these subroutines you can run the G71f (or G72f) routine on its own. That will allow you to repeat the finish cut to final dimensions.
2.5.1 Linuxcnc
Nothing to do with this thread, try posting here
www.linuxcnc.org/index.php/english/forum...t-patch?limitstart=0
18 May 2013 13:33 #34325 by DaOne
Are these subroutines still available? The link is no longer working. Any chance at an imperial version?
Thanks,
Wes
18 May 2013 16:50 - 18 May 2013 16:54 #34327 by ArcEye
Hi
I changed servers, this link got orphaned.
The file size limits have changed so I can post it here now instead.
No chance of imperial sorry, I don't use it and the industry in the UK has not used imperial really since the mid 70's.
They should not be too hard to convert, the only 'metric' thing about them really is the default gcodes in the startup lines and the default values in the ngcgui fields.
File Name: Lathe_G71_...subs.zip
File Size:515 KB
Last edit: 18 May 2013 16:54 by ArcEye.
The following user(s) said Thank You: RotarySMP, mariusl, Diederik, ts14, robertspark
18 May 2013 20:59 #34332 by jlviloria
Replied by jlviloria on topic Metric Lathe subroutines - G71, G72, etc etc
ArcEye
greetings, you can use the "run at line" with subroutines, I read that it is not recommended, there will be a form that can be used?
Thanks.
Jorge
Time to create page: 0.467 seconds
