boundaries pin in AXIS
- fupeama
- Thank you received: 16
13 Apr 2015 20:00 #57746
by fupeama
boundaries pin in AXIS was created by fupeama
Hi, is there any posibilities to get min and max coordinates from loaded G-code to pins?
I need make some glade buttons to move to xmin xmax and ymin ymax for check work place.
I find same calculations in AXIS (properties XYZ bounds), but it is only internal value, not hal pin in axisui.
it is no problem to define pins myself and calculate this value in axis.py but I'd radher use something from official distribution.
Thanks Martin
Thanks Martin
- Thank you received: 4976
13 Apr 2015 22:08 #57757
It might be possible to do this in the .axisrc file:
linuxcnc.org/docs/html/gui/axis.html#_axisrc
You can certainly _create_ the pins easily enough with .axisrc. Whether it is as as easy to make the pins update is a different question.
Replied by andypugh on topic boundaries pin in AXIS
- dgarrett
- Thank you received: 325
13 Apr 2015 23:06 #57759
by dgarrett
Replied by dgarrett on topic boundaries pin in AXIS
In axis.py, the LivePlotter class periodically calls a function named update.
At the end of this function there is a call to user_live_update()
which is served by a no-op placeholder.
So an .axisrc file (or a [DISPLAY]USER_COMMAND_FILE) can define a
user_live_update() function which is served periodically like other updates.
ref:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...2154e975686b8db32229
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...c4d160754b6420bd7df4
ref:
13 Apr 2015 23:17 #57761
Just to explain, the advantage of using a .axisrc file to customise Axis behaviour is that the modification will still work if Axis (and LinuxCNC) is updated.
- dgarrett
13 Apr 2015 23:21 #57762
by dgarrett
And another clarification:
a user's ~/.axisrc file is invoked for any ini file used by the user account
an ini option for [DISPLAY]USER_COMMAND_FILE supersedes the ~/.axisrc file
and makes it possible to do axis gui customizations on a per inifile basis
- fupeama
16 Apr 2015 23:41 #57846
by fupeama
Replied by fupeama on topic boundaries pin in AXIS
Thanks for advice
This information is exactly what I want.
Here is my solutionMartin
Here is my solution
if hal_present:
mycomp = hal.component("boundaries")
mycomp.newpin("max_lim_x",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("min_lim_x",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("mid_lim_x",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("max_lim_y",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("min_lim_y",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("mid_lim_y",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("max_lim_z",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("min_lim_z",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.newpin("mid_lim_z",hal.HAL_FLOAT,hal.HAL_OUT)
mycomp.ready()
if vars.metric.get():
conv = 1
else:
conv = 1/25.4
# this function is called at [DISPLAY]CYCLE_TIME interval
def user_live_update():
min_extents = from_internal_units(o.canon.min_extents, conv)
max_extents = from_internal_units(o.canon.max_extents, conv)
mycomp['min_lim_x'] = min_extents[0]
mycomp['max_lim_x'] = max_extents[0]
mycomp['mid_lim_x'] = min_extents[0] + (max_extents[0] - min_extents[0])/2
mycomp['min_lim_y'] = min_extents[1]
mycomp['max_lim_y'] = max_extents[1]
mycomp['mid_lim_y'] = min_extents[1]+ (max_extents[1] - min_extents[1])/2
mycomp['min_lim_z'] = min_extents[2]
mycomp['max_lim_z'] = max_extents[2]
mycomp['mid_lim_z'] = min_extents[2]+ (max_extents[2] - min_extents[2])/2
Time to create page: 0.079 seconds
