No linuxCNC widgets with Wheezy-iso 2.6.0~pre5
- _eric_
26 Jul 2014 02:22 #49140
by _eric_
No linuxCNC widgets with Wheezy-iso 2.6.0~pre5 was created by _eric_
Hello,
I have just made (yesterday) a fresh install of the Wheezy-iso 2.6.0~pre5 (new RTAI) found here:
www.linuxcnc.org/binary.hybrid.iso
Thank you very much all the team, great job!
I have also made a Glade install (3.12.1), but Glade don’t find the LinuxCNC-specific widgets.
What can I do ?
What can I do ?
- ArcEye
- Thank you received: 758
26 Jul 2014 15:25 #49164
by ArcEye
Replied by ArcEye on topic No linuxCNC widgets with Wheezy-iso 2.6.0~pre5
Hi
I think you will find that glade is just broken as far as gladevcp goes once you get to version 3.12
You will have to see if you can downgrade to 3.8 and get all the necessary libraries.
see this bug report
sourceforge.net/p/emc/bugs/352/
Because glade is reliant on gtk, which seems to have no future, a lot of effort is going into a Qt based interface over on the MachineKit fork
but it is not finished yet
see this bug report
The following user(s) said Thank You: _eric_
- _eric_
26 Jul 2014 20:46 #49171
by _eric_
Replied by _eric_ on topic No linuxCNC widgets with Wheezy-iso 2.6.0~pre5
Thank you very much.
I have installed Glade3.6.7 from squeeze.
All the linuxcnc widgets are now in the left panel.
1) remove first Glade 3.12.1:
sudo apt-get remove glade
sudo apt-get autoremove
2) add squeeze sources in /etc/apt/sources.list and update with:
sudo apt-get update
3) verify glade versions candidate:
sudo apt-cache policy glade
glade:
Installé : (aucun)
Candidat : 3.12.1-1
Table de version :
3.12.1-1 0
500 http.debian.net/debian/ wheezy/main i386 Packages
100 /var/lib/dpkg/status
3.6.7-1+b1 0
500 ftp.fr.debian.org/debian/ squeeze/main i386 Packages
4) install glade3.6.7 with dependencies:
sudo apt-get install glade=3.6.7-1+b1
5) verify wich glade is now installed:
glade --version
glade3 3.6.7
sudo apt-get update
glade:
Installé : (aucun)
Candidat : 3.12.1-1
Table de version :
3.12.1-1 0
3.6.7-1+b1 0
glade --version
glade3 3.6.7
Moderators: HansU
Time to create page: 0.049 seconds
