GladeVCP hot-keys on widgets
- Nick
- Thank you received: 11
If we pack GladeVCP panel into axis hot-keys do not work at all.
How to make them work?
- ArcEye
- Thank you received: 240
I suspect this will be connected with the whole key focus problem when you embed anything into the kludge that is Axis.
I seem to remember it is something to do with Tk/Tcl not conforming to X Window standards for key forwarding.
The gladevcp panels rely upon a handler to pump keystrokes back into Axis when it has focus, or important keys like Escape don't get through.
I likewise wrote Qt vcp panels that functioned perfectly as stand alone entities, but when embedded in Axis, all sorts of issues arose that would have required
a low level key handler module to resolve, simply because Axis child windows do not get key events as they should.
I just gave up embedding in Axis.
So the answer is probably, with great difficulty or not at all.
- Nick
Don't you know is the situation the with other user interfaces like gmoccapy?
- ArcEye
It should be a better candidate
You will need to ask Norbert or Chris Morley on that one, I don't know much about it
- newbynobi
- Thank you received: 394
Gmoccapy does support allready some key events, they are implemented in gmoccapy.py in def on_key_event
You can add here more keys.
Gscreen does even support user configurable key events, if i remember correct.
I am planing to incorporate a separate ini file for user key events, but please do mot ask for a deadline.
I do not know if that can be made working also with embedded glade panels, as the main gui does not know the widgets and only the main window does accept key evenfs, at least as long as they do have the focus.. I will have a look on that in the very far feature....
Norbert
- Nick
Hotkeys do not work even if current widget have focus on it.
For example, panel with button. If we put focus in it we can activate it either by pressing space bar or enter, but it's hotkey still does not work...
- newbynobi
how did you add the hotkey?
Sample code?
Does it work stand allone?
Norbert
There are Accelerators (aka hot-keys) in Common tab of most widgets. And they work but only in stand alone window.
I have found the opposite problem. When the mouse pointer is in my embedded Glade panel, the Axis keys don't work. I need to move the pointer out of the embedded Glade tab to be able to jog with the keyboard.
I am just living with this at the moment.
There is probably something to be done by changing keyboard_forward() here:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...0dde4bf3edaf67c5ce71
- Nick
@Nick,
Sample code?
Just add "Accelerator" in glade in widget's parameters (Common parameters tab).
Yes it works in a standalone.
- ArcEye
That was the keyboard handler I mentioned earlier, had to be introduced with gladevcp to get embedded panels working safely or nothing got back to Axis
