Crash when start EMC2 error.
10 Jul 2014 01:38 - 10 Jul 2014 01:58 #48592 by lmendpin
Crash when start EMC2 error. was created by lmendpin
Hello I can not start EMC2 send a error debug
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/sherline/emc2/configs/Sherline4Axis'
Machine configuration file is 'Sherline4Axis_inch.ini'
INIFILE=/home/sherline/emc2/configs/Sherline4Axis/Sherline4Axis_inch.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=mini
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=3534
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
3534
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009e000 (usable)
[    0.000000]  BIOS-e820: 000000000009e000 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000d8000 - 00000000000e0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 0000000027cf0000 (usable)
[    0.000000]  BIOS-e820: 0000000027cf0000 - 0000000027cfc000 (ACPI data)
[    0.000000]  BIOS-e820: 0000000027cfc000 - 0000000027d00000 (ACPI NVS)
[    0.000000]  BIOS-e820: 0000000027d00000 - 0000000027e80000 (usable)
[    0.000000]  BIOS-e820: 0000000027e80000 - 0000000028000000 (reserved)
[    0.000000]  BIOS-e820: 00000000ff800000 - 00000000ffc00000 (reserved)
[    0.000000]  BIOS-e820: 00000000fffffc00 - 0000000100000000 (reserved)
[    0.000000] DMI present.
[    0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] last_pfn = 0x27e80 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-C7FFF write-protect
[    0.000000]   C8000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FE0000000 write-back
[    0.000000]   1 base 020000000 mask FF8000000 write-back
[    0.000000]   2 base 027F80000 mask FFFF80000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] PAT not supported by CPU.
[    0.000000] Scanning 0 areas for low memory corruption
[    0.000000] modified physical RAM map:
[    0.000000]  modified: 0000000000000000 - 0000000000010000 (reserved)
[    0.000000]  modified: 0000000000010000 - 000000000009e000 (usable)
[    0.000000]  modified: 000000000009e000 - 00000000000a0000 (reserved)
[    0.000000]  modified: 00000000000d8000 - 00000000000e0000 (reserved)
[    0.000000]  modified: 00000000000e4000 - 0000000000100000 (reserved)
[    0.000000]  modified: 0000000000100000 - 0000000027cf0000 (usable)
[    0.000000]  modified: 0000000027cf0000 - 0000000027cfc000 (ACPI data)
[    0.000000]  modified: 0000000027cfc000 - 0000000027d00000 (ACPI NVS)
[    0.000000]  modified: 0000000027d00000 - 0000000027e80000 (usable)
[    0.000000]  modified: 0000000027e80000 - 0000000028000000 (reserved)
[    0.000000]  modified: 00000000ff800000 - 00000000ffc00000 (reserved)
[    0.000000]  modified: 00000000fffffc00 - 0000000100000000 (reserved)
[    0.000000] initial memory mapped : 0 - 00c00000
[    0.000000] init_memory_mapping: 0000000000000000-0000000027e80000
[    0.000000] Using x86 segment limits to approximate NX protection
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 0027c00000 page 2M
[    0.000000]  0027c00000 - 0027e80000 page 4k
[    0.000000] kernel direct mapping tables up to 27e80000 @ 10000-15000
[    0.000000] RAMDISK: 1d144000 - 1ddf3648
[    0.000000] ACPI: RSDP 000f6b40 00014 (v00 SONY  )
[    0.000000] ACPI: RSDT 27cf6f2f 0002C (v01 SONY   C1       20020814 PTL  00000000)
[    0.000000] ACPI: FACP 27cfbf64 00074 (v01   SONY       C1 20020814 PTL  01000000)
[    0.000000] ACPI: DSDT 27cf6f5b 05009 (v01   SONY       C1 20020814 PTL  0100000D)
[    0.000000] ACPI: FACS 27cfcfc0 00040
[    0.000000] ACPI: BOOT 27cfbfd8 00028 (v01   SONY       C1 20020814 PTL  00000001)
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 638MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 27e80000
[    0.000000]   low ram: 0 - 27e80000
[    0.000000]   node 0 low ram: 00000000 - 27e80000
[    0.000000]   node 0 bootmap 00011000 - 00015fd0
[    0.000000] (9 early reservations) ==> bootmem [0000000000 - 0027e80000]
[    0.000000]   #0 [0000000000 - 0000001000]   BIOS data page ==> [0000000000 - 0000001000]
[    0.000000]   #1 [0000001000 - 0000002000]    EX TRAMPOLINE ==> [0000001000 - 0000002000]
[    0.000000]   #2 [0000006000 - 0000007000]       TRAMPOLINE ==> [0000006000 - 0000007000]
[    0.000000]   #3 [0000100000 - 00008b0db8]    TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[    0.000000]   #4 [001d144000 - 001ddf3648]          RAMDISK ==> [001d144000 - 001ddf3648]
[    0.000000]   #5 [000009e000 - 0000100000]    BIOS reserved ==> [000009e000 - 0000100000]
[    0.000000]   #6 [00008b1000 - 00008b4120]              BRK ==> [00008b1000 - 00008b4120]
[    0.000000]   #7 [0000010000 - 0000011000]          PGTABLE ==> [0000010000 - 0000011000]
[    0.000000]   #8 [0000011000 - 0000016000]          BOOTMAP ==> [0000011000 - 0000016000]
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x00027e80
[    0.000000]   HighMem  0x00027e80 -> 0x00027e80
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[3] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009e
[    0.000000]     0: 0x00000100 -> 0x00027cf0
[    0.000000]     0: 0x00027d00 -> 0x00027e80
[    0.000000] On node 0 totalpages: 163326
[    0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3950 pages, LIFO batch:0
[    0.000000]   Normal zone: 1245 pages used for memmap
[    0.000000]   Normal zone: 158099 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x1008
[    0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[    0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[    0.000000] APIC: disable apic facility
[    0.000000] nr_irqs_gsi: 16
[    0.000000] Allocating PCI resources starting at 28000000 (gap: 28000000:d7800000)
[    0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[    0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[    0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 162049
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=8b1596ba-b964-4a7d-96cc-cf3005e3fe6d ro quiet splash
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Enabling fast FPU save and restore... done.
[    0.000000] Enabling unmasked SIMD FPU exception support... done.
[    0.000000] Initializing CPU#0
[    0.000000] allocated 3268800 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (00000000:00000000)
[    0.000000] Memory: 622816k/653824k available (4539k kernel code, 30116k reserved, 1928k data, 620k init, 0k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff1e000 - 0xfffff000   ( 900 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xe8680000 - 0xff7fe000   ( 369 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe7e80000   ( 638 MB)
[    0.000000]       .init : 0xc0751000 - 0xc07ec000   ( 620 kB)
[    0.000000]       .data : 0xc056ecbc - 0xc0750e68   (1928 kB)
[    0.000000]       .text : 0xc0100000 - 0xc056ecbc   (4539 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:2304 nr_irqs:256
[    0.000000] I-pipe 2.6-03: pipeline enabled.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 1126.962 MHz processor.
[    0.004009] Calibrating delay loop (skipped), value calculated using timer frequency.. 2253.92 BogoMIPS (lpj=4507848)
[    0.004052] Security Framework initialized
[    0.004116] AppArmor: AppArmor initialized
[    0.004136] Mount-cache hash table entries: 512
[    0.008220] Initializing cgroup subsys ns
[    0.008231] Initializing cgroup subsys cpuacct
[    0.008242] Initializing cgroup subsys memory
[    0.008265] Initializing cgroup subsys devices
[    0.008272] Initializing cgroup subsys freezer
[    0.008278] Initializing cgroup subsys net_cls
[    0.008329] CPU: L1 I cache: 16K, L1 D cache: 16K
[    0.008337] CPU: L2 cache: 512K
[    0.008347] mce: CPU supports 5 MCE banks
[    0.008381] Performance Events:
[    0.008387] no APIC, boot with the "lapic" boot parameter to force-enable it.
[    0.008393] no hardware sampling interrupt available.
[    0.008399] p6 PMU driver.
[    0.008423] ... version:                0
[    0.008428] ... bit width:              32
[    0.008433] ... generic registers:      2
[    0.008438] ... value mask:             00000000ffffffff
[    0.008444] ... max period:             000000007fffffff
[    0.008449] ... fixed-purpose events:   0
[    0.008455] ... event mask:             0000000000000003
[    0.008466] Checking 'hlt' instruction... OK.
[    0.025372] SMP alternatives: switching to UP code
[    0.034596] Freeing SMP alternatives: 31k freed
[    0.034622] ACPI: Core revision 20090903
[    0.048161] ftrace: converting mcount calls to 0f 1f 44 00 00
[    0.048184] ftrace: allocating 21003 entries in 42 pages
[    0.063329] Enabling APIC mode:  Flat.  Using 0 I/O APICs
[    0.063343] weird, boot CPU (#0) not listed by the BIOS.
[    0.063348] SMP motherboard not detected.
[    0.063354] Local APIC not detected. Using dummy APIC emulation.
[    0.063359] SMP disabled
[    0.063819] Brought up 1 CPUs
[    0.063833] Total of 1 processors activated (2253.92 BogoMIPS).
[    0.064054] CPU0 attaching NULL sched-domain.
[    0.064385] devtmpfs: initialized
[    0.065190] regulator: core version 0.5
[    0.065304] NET: Registered protocol family 16
[    0.065579] EISA bus registered
[    0.065596] ACPI: bus type pci registered
[    0.074345] PCI: PCI BIOS revision 2.10 entry at 0xfd9aa, last bus=2
[    0.074352] PCI: Using configuration type 1 for base access
[    0.076283] bio: create slab <bio-0> at 0
[    0.077565] ACPI: EC: Look up EC in DSDT
[    0.085855] ACPI: Interpreter enabled
[    0.085865] ACPI: (supports S0 S5)
[    0.085886] ACPI: Using PIC for interrupt routing
[    0.118208] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[    0.118475] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[    0.121580] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.121719] pci 0000:00:02.0: reg 10 32bit mmio pref: [0xe8000000-0xefffffff]
[    0.121730] pci 0000:00:02.0: reg 14 32bit mmio: [0xe0000000-0xe007ffff]
[    0.121759] pci 0000:00:02.0: supports D1
[    0.121786] pci 0000:00:02.1: reg 10 32bit mmio pref: [0xf0000000-0xf7ffffff]
[    0.121796] pci 0000:00:02.1: reg 14 32bit mmio: [0xe0080000-0xe00fffff]
[    0.121825] pci 0000:00:02.1: supports D1
[    0.121904] pci 0000:00:1d.0: reg 20 io port: [0x1800-0x181f]
[    0.121962] pci 0000:00:1d.1: reg 20 io port: [0x1820-0x183f]
[    0.122020] pci 0000:00:1d.2: reg 20 io port: [0x1840-0x185f]
[    0.122132] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
[    0.122141] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH4 GPIO
[    0.122179] pci 0000:00:1f.1: reg 10 io port: [0x1f0-0x1f7]
[    0.122190] pci 0000:00:1f.1: reg 14 io port: [0x3f4-0x3f7]
[    0.122202] pci 0000:00:1f.1: reg 18 io port: [0x170-0x177]
[    0.122213] pci 0000:00:1f.1: reg 1c io port: [0x374-0x377]
[    0.122224] pci 0000:00:1f.1: reg 20 io port: [0x1860-0x186f]
[    0.122235] pci 0000:00:1f.1: reg 24 32bit mmio: [0xe0100000-0xe01003ff]
[    0.122294] pci 0000:00:1f.3: reg 20 io port: [0x1880-0x189f]
[    0.122336] pci 0000:00:1f.5: reg 10 io port: [0x1c00-0x1cff]
[    0.122348] pci 0000:00:1f.5: reg 14 io port: [0x18c0-0x18ff]
[    0.122402] pci 0000:00:1f.6: reg 10 io port: [0x2400-0x24ff]
[    0.122413] pci 0000:00:1f.6: reg 14 io port: [0x2000-0x207f]
[    0.122490] pci 0000:02:02.0: reg 10 32bit mmio: [0xe0205000-0xe02057ff]
[    0.122502] pci 0000:02:02.0: reg 14 32bit mmio: [0xe0200000-0xe0203fff]
[    0.122544] pci 0000:02:02.0: supports D1 D2
[    0.122550] pci 0000:02:02.0: PME# supported from D0 D1 D2 D3hot
[    0.122559] pci 0000:02:02.0: PME# disabled
[    0.122597] pci 0000:02:05.0: reg 10 32bit mmio: [0x000000-0x000fff]
[    0.122617] pci 0000:02:05.0: supports D1 D2
[    0.122623] pci 0000:02:05.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.122631] pci 0000:02:05.0: PME# disabled
[    0.122669] pci 0000:02:08.0: reg 10 32bit mmio: [0xe0204000-0xe0204fff]
[    0.122680] pci 0000:02:08.0: reg 14 io port: [0x3000-0x303f]
[    0.122720] pci 0000:02:08.0: supports D1 D2
[    0.122725] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.122733] pci 0000:02:08.0: PME# disabled
[    0.122768] pci 0000:00:1e.0: transparent bridge
[    0.122777] pci 0000:00:1e.0: bridge io port: [0x3000-0x3fff]
[    0.122785] pci 0000:00:1e.0: bridge 32bit mmio: [0xe0200000-0xe02fffff]
[    0.122820] pci_bus 0000:00: on NUMA node 0
[    0.122830] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.123005] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB_._PRT]
[    0.127492] ACPI: PCI Interrupt Link [LNKA] (IRQs *9)
[    0.127697] ACPI: PCI Interrupt Link [LNKB] (IRQs 9) *0, disabled.
[    0.127904] ACPI: PCI Interrupt Link [LNKC] (IRQs 9) *0, disabled.
[    0.128236] ACPI: PCI Interrupt Link [LNKD] (IRQs *9)
[    0.128539] ACPI: PCI Interrupt Link [LNKE] (IRQs *9)
[    0.128843] ACPI: PCI Interrupt Link [LNKF] (IRQs 9) *0
[    0.129042] ACPI: PCI Interrupt Link [LNKG] (IRQs 9) *0, disabled.
[    0.129241] ACPI: PCI Interrupt Link [LNKH] (IRQs 9) *0, disabled.
[    0.129478] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.129496] vgaarb: loaded
[    0.129795] SCSI subsystem initialized
[    0.129968] libata version 3.00 loaded.
[    0.130140] usbcore: registered new interface driver usbfs
[    0.130172] usbcore: registered new interface driver hub
[    0.130238] usbcore: registered new device driver usb
[    0.130536] ACPI: WMI: Mapper loaded
[    0.130542] PCI: Using ACPI for IRQ routing
[    0.130842] NetLabel: Initializing
[    0.130848] NetLabel:  domain hash size = 128
[    0.130852] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.130883] NetLabel:  unlabeled traffic allowed by default
[    0.130969] Switching to clocksource tsc
[    0.132432] AppArmor: AppArmor Filesystem Enabled
[    0.132483] pnp: PnP ACPI init
[    0.132532] ACPI: bus type pnp registered
[    0.177010] pnp: PnP ACPI: found 12 devices
[    0.177018] ACPI: ACPI bus type pnp unregistered
[    0.177028] PnPBIOS: Disabled by ACPI PNP
[    0.177058] system 00:01: ioport range 0x1000-0x107f has been reserved
[    0.177066] system 00:01: ioport range 0x1180-0x11bf has been reserved
[    0.177075] system 00:01: ioport range 0x600-0x60f has been reserved
[    0.177082] system 00:01: ioport range 0x4d0-0x4d1 has been reserved
[    0.177090] system 00:01: ioport range 0xfe00-0xfe01 has been reserved
[    0.177098] system 00:01: ioport range 0xfe10-0xfe17 has been reserved
[    0.177108] system 00:01: iomem range 0xfebffc00-0xfebfffff has been reserved
[    0.177117] system 00:01: iomem range 0xff800000-0xffffffff could not be reserved
[    0.212119] pci 0000:02:05.0: CardBus bridge, secondary bus 0000:03
[    0.212126] pci 0000:02:05.0:   IO window: 0x003400-0x0034ff
[    0.212135] pci 0000:02:05.0:   IO window: 0x003800-0x0038ff
[    0.212143] pci 0000:02:05.0:   PREFETCH window: 0x28000000-0x2bffffff
[    0.212152] pci 0000:02:05.0:   MEM window: 0x2c000000-0x2fffffff
[    0.212161] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[    0.212168] pci 0000:00:1e.0:   IO window: 0x3000-0x3fff
[    0.212178] pci 0000:00:1e.0:   MEM window: 0xe0200000-0xe02fffff
[    0.212187] pci 0000:00:1e.0:   PREFETCH window: 0x28000000-0x2bffffff
[    0.212210] pci 0000:00:1e.0: setting latency timer to 64
[    0.212236] pci 0000:02:05.0: power state changed by ACPI to D0
[    0.212730] ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 9
[    0.212738] PCI: setting IRQ 9 as level-triggered
[    0.212746] pci 0000:02:05.0: PCI INT A -> Link[LNKF] -> GSI 9 (level, low) -> IRQ 9
[    0.212761] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
[    0.212768] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[    0.212776] pci_bus 0000:02: resource 0 io:  [0x3000-0x3fff]
[    0.212783] pci_bus 0000:02: resource 1 mem: [0xe0200000-0xe02fffff]
[    0.212790] pci_bus 0000:02: resource 2 pref mem [0x28000000-0x2bffffff]
[    0.212797] pci_bus 0000:02: resource 3 io:  [0x00-0xffff]
[    0.212804] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[    0.212811] pci_bus 0000:03: resource 0 io:  [0x3400-0x34ff]
[    0.212818] pci_bus 0000:03: resource 1 io:  [0x3800-0x38ff]
[    0.212825] pci_bus 0000:03: resource 2 pref mem [0x28000000-0x2bffffff]
[    0.212832] pci_bus 0000:03: resource 3 mem: [0x2c000000-0x2fffffff]
[    0.212922] NET: Registered protocol family 2
[    0.213178] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.214001] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.218346] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.221099] TCP: Hash tables configured (established 131072 bind 65536)
[    0.221116] TCP reno registered
[    0.221476] NET: Registered protocol family 1
[    0.221551] pci 0000:00:02.0: Boot video device
[    0.221669] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[    0.221971] Simple Boot Flag at 0x36 set to 0x1
[    0.222239] Scanning for low memory corruption every 60 seconds
[    0.222504] audit: initializing netlink socket (disabled)
[    0.222556] type=2000 audit(1404856558.220:1): initialized
[    0.238168] Trying to unpack rootfs image as initramfs...
[    0.257714] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.265075] VFS: Disk quotas dquot_6.5.2
[    0.265301] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.267029] fuse init (API version 7.13)
[    0.267271] msgmni has been set to 1217
[    0.273343] alg: No test for stdrng (krng)
[    0.273549] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.273559] io scheduler noop registered
[    0.273564] io scheduler anticipatory registered
[    0.273569] io scheduler deadline registered
[    0.273710] io scheduler cfq registered (default)
[    0.274010] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.274069] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.274257] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.274638] ACPI: Lid Switch [LID]
[    0.274749] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.274762] ACPI: Power Button [PWRB]
[    0.282028] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.282166] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.282881] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.283061] serial 0000:00:1f.6: enabling device (0000 -> 0001)
[    0.283677] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
[    0.283689] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 9 (level, low) -> IRQ 9
[    0.283706] serial 0000:00:1f.6: PCI INT B disabled
[    0.285062] isapnp: Scanning for PnP cards...
[    0.294284] brd: module loaded
[    0.295451] loop: module loaded
[    0.295725] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[    0.296009] ata_piix 0000:00:1f.1: version 2.13
[    0.296038] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[    0.296050] ata_piix 0000:00:1f.1: can't derive routing for PCI INT A
[    0.296140] ata_piix 0000:00:1f.1: setting latency timer to 64
[    0.345028] scsi0 : ata_piix
[    0.345389] scsi1 : ata_piix
[    0.346553] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1860 irq 14
[    0.346562] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1868 irq 15
[    0.347472] Fixed MDIO Bus: probed
[    0.347562] PPP generic driver version 2.4.2
[    0.347719] tun: Universal TUN/TAP device driver, 1.6
[    0.347724] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.347967] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.348015] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.348047] uhci_hcd: USB Universal Host Controller Interface driver
[    0.348237] uhci_hcd 0000:00:1d.0: power state changed by ACPI to D0
[    0.348739] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 9
[    0.348749] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 9 (level, low) -> IRQ 9
[    0.348767] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    0.348775] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.348867] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[    0.348909] uhci_hcd 0000:00:1d.0: irq 9, io base 0x00001800
[    0.353444] usb usb1: configuration #1 chosen from 1 choice
[    0.353521] hub 1-0:1.0: USB hub found
[    0.353543] hub 1-0:1.0: 2 ports detected
[    0.353846] uhci_hcd 0000:00:1d.1: power state changed by ACPI to D0
[    0.354396] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
[    0.354407] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 9 (level, low) -> IRQ 9
[    0.354427] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    0.354436] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.354543] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[    0.354588] uhci_hcd 0000:00:1d.1: irq 9, io base 0x00001820
[    0.354809] usb usb2: configuration #1 chosen from 1 choice
[    0.354878] hub 2-0:1.0: USB hub found
[    0.354898] hub 2-0:1.0: 2 ports detected
[    0.355062] uhci_hcd 0000:00:1d.2: power state changed by ACPI to D0
[    0.355548] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 9
[    0.355557] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 9 (level, low) -> IRQ 9
[    0.355569] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    0.355576] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.355678] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[    0.355710] uhci_hcd 0000:00:1d.2: irq 9, io base 0x00001840
[    0.355913] usb usb3: configuration #1 chosen from 1 choice
[    0.355985] hub 3-0:1.0: USB hub found
[    0.356003] hub 3-0:1.0: 2 ports detected
[    0.356220] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUE] at 0x60,0x64 irq 1,12
[    0.361573] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.361602] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.361996] mice: PS/2 mouse device common for all mice
[    0.362273] rtc_cmos 00:04: RTC can wake from S4
[    0.362384] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[    0.362418] rtc0: alarms up to one month, y3k, 114 bytes nvram
[    0.362687] device-mapper: uevent: version 1.0.3
[    0.365628] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[    0.369027] device-mapper: multipath: version 1.1.0 loaded
[    0.369039] device-mapper: multipath round-robin: version 1.0.0 loaded
[    0.369536] EISA: Probing bus 0 at eisa.0
[    0.369551] Cannot allocate resource for EISA slot 1
[    0.369558] Cannot allocate resource for EISA slot 2
[    0.369564] Cannot allocate resource for EISA slot 3
[    0.369591] EISA: Detected 0 cards.
[    0.369599] cpuidle: using governor ladder
[    0.369605] cpuidle: using governor menu
[    0.370731] TCP cubic registered
[    0.371216] NET: Registered protocol family 10
[    0.372314] lo: Disabled Privacy Extensions
[    0.373159] NET: Registered protocol family 17
[    0.373245] Using IPI No-Shortcut mode
[    0.373514] registered taskstats version 1
[    0.373909] rtc_cmos 00:04: setting system clock to 2014-07-08 21:55:59 UTC (1404856559)
[    0.373917] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.373922] EDD information not available.
[    0.393670] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    0.542399] ata1.00: ATA-5: IC25N030ATCS04-0, CA3OA71A, max UDMA/100
[    0.542411] ata1.00: 58605120 sectors, multi 16: LBA
[    0.557947] ata1.00: configured for UDMA/100
[    0.709066] usb 3-1: new full speed USB device using uhci_hcd and address 2
[    0.973193] isapnp: No Plug & Play device found
[    0.973698] scsi 0:0:0:0: Direct-Access     ATA      IC25N030ATCS04-0 CA3O PQ: 0 ANSI: 5
[    0.974162] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    0.974417] sd 0:0:0:0: [sda] 58605120 512-byte logical blocks: (30.0 GB/27.9 GiB)
[    0.974557] sd 0:0:0:0: [sda] Write Protect is off
[    0.974567] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.974635] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.975009]  sda:
[    1.000088] usb 3-1: configuration #1 chosen from 1 choice
[    1.000981]  sda1 sda2 < sda5 >
[    1.032403] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.333403] Freeing initrd memory: 12989k freed
[    1.372274] Freeing unused kernel memory: 620k freed
[    1.374293] Write protecting the kernel text: 4540k
[    1.374365] Write protecting the kernel read-only data: 1668k
[    1.427702] ramzswap: disk size set to 318416 kB
[    1.444450] udev: starting version 151
[    1.586877] Adding 318412k swap on /dev/ramzswap0.  Priority:100 extents:1 across:318412k SS
[    2.008394] Linux agpgart interface v0.103
[    2.010756] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input4
[    2.010963] ACPI: Video Device [GCH0] (multi-head: yes  rom: no  post: no)
[    2.047881] Initializing USB Mass Storage driver...
[    2.058260] Floppy drive(s): fd0 is 1.44M
[    2.058454] scsi2 : SCSI emulation for USB Mass Storage devices
[    2.058821] usbcore: registered new interface driver usb-storage
[    2.058829] USB Mass Storage support registered.
[    2.059024] usb-storage: device found at 2
[    2.059029] usb-storage: waiting for device to settle before scanning
[    2.069409] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[    2.069424] e100: Copyright(c) 1999-2006 Intel Corporation
[    2.070149] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 9
[    2.070161] e100 0000:02:08.0: PCI INT A -> Link[LNKE] -> GSI 9 (level, low) -> IRQ 9
[    2.093316] e100 0000:02:08.0: PME# disabled
[    2.097823] FDC 0 is a post-1991 82077
[    2.109111] agpgart-intel 0000:00:00.0: Intel 830M Chipset
[    2.109657] agpgart-intel 0000:00:00.0: detected 892K stolen memory
[    2.112110] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[    2.186070] e100: eth0: e100_probe: addr 0xe0204000, irq 9, MAC addr 08:00:46:4f:24:28
[    2.186156] ohci1394 0000:02:02.0: PCI INT A -> Link[LNKC] -> GSI 9 (level, low) -> IRQ 9
[    2.188748] [drm] Initialized drm 1.1.0 20060810
[    2.264700] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[9]  MMIO=[e0205000-e02057ff]  Max Packet=[2048]  IR/IT contexts=[4/8]
[    2.267832] [drm] i915 disabling kernel modesetting for known bad device.
[    2.267886] pci 0000:00:02.0: PCI INT A -> Link[LNKA] -> GSI 9 (level, low) -> IRQ 9
[    2.267898] pci 0000:00:02.0: setting latency timer to 64
[    2.280473] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[    2.287840] vga16fb: initializing
[    2.287856] vga16fb: mapped to 0xc00a0000
[    2.288166] fb0: VGA16 VGA frame buffer device
[    2.441595] Console: switching to colour frame buffer device 80x30
[    2.908158] xor: automatically using best checksumming function: pIII_sse
[    2.928024]    pIII_sse  :  2662.000 MB/sec
[    2.928030] xor: using function: pIII_sse (2662.000 MB/sec)
[    2.968199] device-mapper: dm-raid45: initialized v0.2594b
[    3.257248] EXT4-fs (sda1): mounted filesystem with ordered data mode
[    3.536161] ieee1394: The root node is not cycle master capable; selecting a new root node and resetting...
[    3.813115] ieee1394: Node added: ID:BUS[0-00:1023]  GUID[08004603011debfd]
[    3.813313] ieee1394: Host added: ID:BUS[0-01:1023]  GUID[08004603010f3e3b]
[    5.697053] Adding 1253368k swap on /dev/sda5.  Priority:-1 extents:1 across:1253368k
[    5.873572] udev: starting version 151
[    7.056145] usb-storage: device scan complete
[    7.059279] scsi 2:0:0:0: Direct-Access     Sony     MSC-U03          1.00 PQ: 0 ANSI: 0 CCS
[    7.066194] sd 2:0:0:0: Attached scsi generic sg1 type 0
[    7.093860] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[    7.360669] sony-laptop: Sony Programmable IO Control Driver v0.6.
[    7.360698] sony-laptop: detected Type2 model
[    7.361985] input: Sony Vaio Keys as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:09/SNY6001:00/input/input5
[    7.363012] input: Sony Vaio Jogdial as /devices/virtual/input/input6
[    7.366150] sony-laptop: device allocated minor is 55
[    7.368513] sony-laptop: Sony Notebook Control Driver v0.6.
[    7.692828] intel_rng: FWH not detected
[    7.760220] input: PS/2 Mouse as /devices/platform/i8042/serio1/input/input7
[    7.776095] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input8
[    7.807949] lp: driver loaded but no devices found
[    7.808762] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    7.844372] parport_pc 00:0a: reported by Plug and Play ACPI
[    7.844433] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[    7.940445] lp0: using parport0 (interrupt-driven).
[    8.163926] ppdev: user-space parallel port driver
[    8.369224] scsi3 : SBP-2 IEEE-1394
[    9.010540] yenta_cardbus 0000:02:05.0: CardBus bridge found [104d:8100]
[    9.136489] yenta_cardbus 0000:02:05.0: ISA IRQ mask 0x0838, PCI irq 9
[    9.136500] yenta_cardbus 0000:02:05.0: Socket status: 30000006
[    9.136509] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #02 to #06
[    9.136531] yenta_cardbus 0000:02:05.0: pcmcia: parent PCI bridge I/O window: 0x3000 - 0x3fff
[    9.136542] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff: clean.
[    9.137061] yenta_cardbus 0000:02:05.0: pcmcia: parent PCI bridge Memory window: 0xe0200000 - 0xe02fffff
[    9.137069] yenta_cardbus 0000:02:05.0: pcmcia: parent PCI bridge Memory window: 0x28000000 - 0x2bffffff
[    9.376540] ieee1394: sbp2: Logged into SBP-2 device
[    9.376652] ieee1394: sbp2: Node 0-00:1023: Max speed [S400] - Max payload [2048]
[    9.383943] scsi 3:0:0:0: CD-ROM            MATSHITA UJDA730 DVD/CDRW 1.00 PQ: 0 ANSI: 0
[    9.624707] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[    9.624720] Uniform CD-ROM driver Revision: 3.20
[    9.625055] sr 3:0:0:0: Attached scsi CD-ROM sr0
[    9.625233] sr 3:0:0:0: Attached scsi generic sg2 type 5
[   10.190583] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[   10.192347] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[   10.193103] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[   10.193760] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[   10.194746] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[   10.417061] type=1505 audit(1404874569.542:2):  operation="profile_load" pid=602 name="/sbin/dhclient3"
[   10.418022] type=1505 audit(1404874569.542:3):  operation="profile_load" pid=602 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   10.418559] type=1505 audit(1404874569.542:4):  operation="profile_load" pid=602 name="/usr/lib/connman/scripts/dhclient-script"
[   10.693028] Intel ICH 0000:00:1f.5: enabling device (0000 -> 0001)
[   10.693049] Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 9 (level, low) -> IRQ 9
[   10.693082] Intel ICH 0000:00:1f.5: setting latency timer to 64
[   11.264052] intel8x0_measure_ac97_clock: measured 55378 usecs (2662 samples)
[   11.264063] intel8x0: clocking to 48000
[   15.808903] type=1505 audit(1404874574.934:5):  operation="profile_load" pid=896 name="/usr/share/gdm/guest-session/Xsession"
[   15.813360] type=1505 audit(1404874574.938:6):  operation="profile_replace" pid=897 name="/sbin/dhclient3"
[   15.814351] type=1505 audit(1404874574.938:7):  operation="profile_replace" pid=897 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   15.814905] type=1505 audit(1404874574.938:8):  operation="profile_replace" pid=897 name="/usr/lib/connman/scripts/dhclient-script"
[   15.935687] type=1505 audit(1404874575.058:9):  operation="profile_load" pid=898 name="/usr/bin/evince"
[   15.952404] type=1505 audit(1404874575.078:10):  operation="profile_load" pid=898 name="/usr/bin/evince-previewer"
[   15.962118] type=1505 audit(1404874575.086:11):  operation="profile_load" pid=898 name="/usr/bin/evince-thumbnailer"
[   16.065126] type=1505 audit(1404874575.190:12):  operation="profile_load" pid=900 name="/usr/lib/cups/backend/cups-pdf"
[   16.066332] type=1505 audit(1404874575.190:13):  operation="profile_load" pid=900 name="/usr/sbin/cupsd"
[   16.114428] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   16.131246] type=1505 audit(1404874575.254:14):  operation="profile_load" pid=903 name="/usr/sbin/tcpdump"
[   53.305156] ISO 9660 Extensions: Microsoft Joliet Level 3
[   53.362165] ISO 9660 Extensions: RRIP_1991A
[   59.576717] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[  215.461582] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[  238.910804] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[  600.131265] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[  977.170947] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1200.034550] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1229.920590] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1247.369423] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1278.900472] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1280.950766] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1281.649629] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1282.202858] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1282.386321] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1282.553721] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1285.976536] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1369.220356] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
Any can help me.
Regards
Luis
Last edit: 10 Jul 2014 01:58 by BigJohnT. Reason: add code tags
10 Jul 2014 02:32 #48593 by PCW
Replied by PCW on topic Crash when start EMC2 error.
is the problem
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
has the solution
The following user(s) said Thank You: lmendpin
25 Jul 2014 04:45 - 25 Jul 2014 12:38 #49108 by vre
Replied by vre on topic Crash when start EMC2 error.
debian 7.6 stable + linuxcnc 2.6pre5 crash when start
Before 1 week worked ok
$ linuxcnc
LINUXCNC - 2.6.0-pre5
$ Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/rtai_hal.ko: Invalid module format
Problem fixed after purge all packages assosiated with linuxcnc and made a clean install from repository.
Last edit: 25 Jul 2014 12:38 by vre.
Time to create page: 0.148 seconds
