Conversion from Mach 3 to LinuxCNC
- BigJohnT
- Thank you received: 1126
06 Mar 2015 20:01 - 18 Aug 2016 15:03 #56512
by BigJohnT
Conversion from Mach 3 to LinuxCNC was created by BigJohnT
I have written a python program that will convert a Mach 3 xml file to a Stepconf file. The file can be opened up in the Stepconf Wizard and it will create the configuration files. I have limited download bandwith so compress the Mach xml file only into a zip file and attach it to your message.
Please use the conversion thread in Stepconf to post your Mach xml file to.
JT
JT
Last edit: 18 Aug 2016 15:03 by andypugh.
The topic has been locked.
- FlyingThinkTank
10 Mar 2015 06:45 #56606
by FlyingThinkTank
Replied by FlyingThinkTank on topic Converstion from Mach 3 to LinuxCNC
I think I screwed up posting the last one; please convert mine! Thanks!
- BigJohnT
11 Mar 2015 18:14 #56665
by BigJohnT
Replied by BigJohnT on topic Converstion from Mach 3 to LinuxCNC
Here you go, I shortened the name down to make it easier for me.
JT
JT
The following user(s) said Thank You: FlyingThinkTank
Time to create page: 0.082 seconds
