Ubuntu 10.404 Lucid | Upgrade 2.5 ->2.7
- hancock
02 Sep 2016 23:13 #79945
by hancock
Ubuntu 10.404 Lucid | Upgrade 2.5 ->2.7 was created by hancock
Hello,
I've tried to upgrade my LinuxCNC 2.5 on Ubuntu Lucid (10.04) to LinuxCNC 2.7 but I always get the following error from the package management:
"linuxcnc:
Dependend: tclx but it is not installable"
I've searched all possible wikis but I can't get any information about the missing tclx.
Any help is highly appreciated.
Cheers,
Hancock
"linuxcnc:
Cheers,
Hancock
- Thank you received: 4584
03 Sep 2016 21:23 #79993
Replied by andypugh on topic Ubuntu 10.404 Lucid | Upgrade 2.5 ->2.7
A suggestion from IRC. If you are on 10.04 it is possible that the repos have moved now that it us no longer supported and that that apt / Synaptic can no longer find _anything_.
What happens if you try to install something that really should exist?
03 Sep 2016 21:31 #79994
Potentially helpful link:
gist.github.com/dergachev/f5da514802fcbbb441a1
- Thank you received: 7181
03 Sep 2016 22:07 #79995
Replied by tommylight on topic Ubuntu 10.404 Lucid | Upgrade 2.5 ->2.7
Andy is right, the repos are changed from "archive" to "old-releases", so a quick change in the sources list ( or synaptics>software sources), and you can update and install like usual. Did that some 4 months ago, it worked. I still use 10.04 on some production machines at clients sites, i just liked it (still do, had it on all my laptops till 7 or 8 months ago).
- dgarrett
- Thank you received: 297
03 Sep 2016 23:31 - 03 Sep 2016 23:32 #79996
by dgarrett
Replied by dgarrett on topic Ubuntu 10.404 Lucid | Upgrade 2.5 ->2.7
The package may be named 'tclx8.4'you could try:
$ dpkg -l '*tclx*'
ii tclx8.4 8.4.1-1 amd64 Extended Tcl (TclX) - shared librarysudo apt-get install tclx8.4
Last edit: 03 Sep 2016 23:32 by dgarrett.
Time to create page: 0.059 seconds
