Installing Uspace for 2.7.7
- Duc
28 Sep 2016 00:19 #81018
by Duc
Installing Uspace for 2.7.7 was created by Duc
Trying to install uspace to run a mesa 7i92 over the ethernet connection.
following the instructions on linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html
all the rtai images have been removed and verified with the uname -v command
#1 SMP PREEMPT RT Debian 3.2.81-2
sentry@Sentry:~/Desktop/7i92-1/7i92/utils/linux$ sudo apt-get install linuxcnc-uspace
[sudo] password for sentry:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc-uspace : Depends: libboost-python1.55.0 but it is not installable
Depends: libc6 (>= 2.15) but 2.13-38+deb7u11 is to be installed
Depends: libfontconfig1 (>= 2.11) but 2.9.0-7.1+deb7u1 is to be installed
Depends: libpango-1.0-0 (>= 1.14.0) but it is not installable
Depends: libpangocairo-1.0-0 (>= 1.14.0) but it is not installable
Depends: libpangoft2-1.0-0 (>= 1.14.0) but it is not installable
Depends: libtk8.6 (>= 8.6.0) but it is not installable
Depends: libudev1 (>= 183) but it is not installable
Depends: tcl8.6 but it is not installable
Depends: tk8.6 but it is not installable
Depends: python:any (>= 2.7.5-5~) but it is not installable
E: Unable to correct problems, you have held broken packages.
Any suggestions on steps or what Im missing.
- Online
- Thank you received: 5086
29 Sep 2016 00:20 #81066
Replied by PCW on topic Installing Uspace for 2.7.7
Are you installing the package on the Wheezy ISO?
That should just work
- Duc
29 Sep 2016 00:33 - 29 Sep 2016 00:33 #81067
by Duc
Yes working with Wheezy ISO.
Got it working after turning off the repositories for Jessie. not sure how that turn on. Stupid little things that can hold projects up.
Replied by Duc on topic Installing Uspace for 2.7.7
Last edit: 29 Sep 2016 00:33 by Duc.
Time to create page: 0.290 seconds
