odtaper_lathe3
- Rick G
- Thank you received: 155
06 Sep 2013 17:32 - 06 Sep 2013 17:35 #38509
by Rick G
odtaper_lathe3 was created by Rick G
Here is an outside diameter taper sub for the lathe that allows you to select the length, start and finish diameter of the taper.
Similar to John's Taper OD which calculates the taper by the angle this uses the start and finish diameter.
For simple lathe without tool offsets, tool change, etc.
Rick G
;odtaper_lathe3 for lathe
;outside diam taper for end of shaft
;UNTESTED concept only, edit and test for your own use before using
;Before running make sure tool is in a position that it can safely travel to Stock Diameter and Z Start.
o<odtaper_lathe3>sub
#<Stock_Diam> = #1 (=1.00 Stock Diameter)
#<Small_Diam> = #2 (=0.625 Small Diameter)
#<Max_Cut> = #3 (=0.010 Max Depth of Cut)
#<Start_z> = #4 (=0.00 Z Start of Cut)
#<End_z> = #5 (=-0.750 Z End of Cut)
#<Feed> = #6 (=4 Feed IPM)
#<RPM> = #7 (=500 RPM)
#<Final_Cut> = #8 (=.005 Final Cut)
#<Fin_ Feed> = #9 (=2 Final cut speed)
#<Spring_Cuts> = #10 (=0 Spring Cuts)
#<Large_Diam_F> = #<Stock_Diam>
#<Small_Diam_F> = #<Small_Diam>
#<Stock_Diam> = [#<Stock_Diam> + #<Final_Cut>]
#<Small_Diam> = [#<Small_Diam> + #<Final_Cut>]
#<Z_Len> = [#<Start_z> - #<End_z>]
#<Cut_Amount> = [#<Stock_Diam> - #<Small_Diam>] ; deepest X cut
#<Cuts> = FUP [[#<Cut_Amount> / #<Max_Cut>]] ; round up the number of passes to reach deepest cut
#<Max_Cut> = [#<Cut_Amount> / #<Cuts>] ; amount to take off X each pass
#<Z_Cut> = [#<Z_Len> / #<Cuts>] ;length of each Z cut
G18 (xz plane)
G20 (inches)
G40 (cancel cutter radius compensation)
G49 (cancel tool length offset)
G90 (absolute distance mode)
G94 (units/min feed rate)
G54 (Coordinant system 1 default)
G7 (diameter mode)
G64 p.001 q.001 (set path tolerance)
; if Z End of Cut is greater than Z Start of Cut do not run
o201 if [#<End_z> gt #<Start_z>]
(debug, Z End of Cut #<End_z># greater than Z Start of Cut #<Start_z>)
o200 return
o201 endif
; if X Stock Diam is less than Small Diam do not run
o301 if [#<Stock_Diam> lt #<Small_Diam>]
(debug, Stock Diam #<Stock_Diam> less than Small Diam #<Small_Diam>)
o300 return
o301 endif
S#<RPM>
F#<Feed>
M3 ; spindle cw
G4 P1 ; pause for spindle to reach RPM
G0 X[#<Stock_Diam> + .010] Z#<Start_z>
G1 X#<Stock_Diam>
#<Current-Diameter> = #<Stock_Diam>
#<Current-Z> = #<Start_z>
#<X_Target> = #<Stock_Diam>
#<Z_Target> = #<Start_z>
o100 while [#<Cuts> gt 0]
#<Current-Diameter> = [#<Current-Diameter> - #<Max_Cut>]
#<Z_Target> = [#<Z_Target> - #<Z_Cut>]
G0 X [#<Current-Diameter> + .010]
G1 X #<Current-Diameter>
G1 X #<Stock_Diam> Z #<Z_Target>
G0 X [#<Stock_Diam> + .010]
G0 Z #<Start_z>
#<Cuts> = [#<Cuts> - 1]
o100 endwhile
;final cut
F#<Fin_ Feed>
G1 X #<Small_Diam_F>
G1 X #<Large_Diam_F> Z #<End_z>
G0 X [#<Large_Diam_F> + .010]
G0 Z #<Start_z>
;spring cuts
o102 while [#<Spring_Cuts> gt 0]
G0 X [#<Small_Diam_F> + .010]
G1 Z #<End_z> X #<Large_Diam_F>
G0 Z #<Start_z>
#<Spring_Cuts> = [#<Spring_Cuts> -1]
o102 endwhile
M5 ; stop spindle
G0 Z #<Start_z>
o<odtaper_lathe3>endsub
Rick G
Last edit: 06 Sep 2013 17:35 by Rick G.
The following user(s) said Thank You: BigJohnT, M4MazakUser, Diederik, Dinuka_Shehan
Time to create page: 0.070 seconds
