  • Murphy
  • Murphy
22 Jan 2025 13:40
Replied by Murphy on topic Spindle location on the opposite side
Category: AXIS
The one labeled Remora
  • JT
  • JT's Avatar
22 Jan 2025 13:23
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Didn't get a chance to update and try the label yet as I'm working on the hal file at the moment. Couple of things I'm noticing now that I'm running some sims......
Since I added a qss, INPUT = TOUCH seems to not have an effect anymore. Pretty sure I had the touch style file browser before the qss but now it is back to the normal one.
The file browser is a little hard to navigate because it doesn't show the current directory, easy to get lost. Any chance you can add current directory at the top or something?
The flood and mist push buttons disable when a program is running. I'm used to Gmoccapy where you can still operate the mist and flood while running a program. Sometimes I forget to add coolant to the program and need to turn it on when it's running. Not quite sure why yet but as soon as the GUI disables coolant even if I stop the program I can't control it again with the hal buttons until I first turn it on with the GUI buttons.
The ini entry INPUT is now THEME gnipsel.com/linuxcnc/flexgui/ini.html#themes
Which file browser, the keyboard or the touch screen?
Good point on the flood and mist and I see no reason to disable them at any time and that has been fixed.
JT
Displaying 19801 - 19802 out of 19802 results.
Time to create page: 0.340 seconds
