05 Feb 2026 00:10
Replied by tommylight on topic Custom PC build for my brothers company and more
Category: Show Your Stuff
Very long and very boring video of the entire shooting session, at 4C in the shop apparently i was in a t-shirt for nearly an hour the first round, roughly 1 and a half hour in a t-shirt, and the worst thing was one of the characters in this video kept using the laser thermometer to check every 5 minutes and reminding me with "how are you not shivering?". Oh well...
No sound, unfortunately, something wrong with the drone cam i used to record this.
  • PCW
  • PCW's Avatar
05 Feb 2026 00:07
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
Category: Driver Boards
Did you manage to program the FPGA via JTAG?
This would be shown by the green LEDs flashing in sequence
and the link and speed LEDs lighting up on the 7I95T's RJ-45
jack.
05 Feb 2026 00:03
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
Had to say "goodbye" to this monstrosity some two weeks ago, but it went with a lot of fanfare and ceremoniously (sorry but i have no video, was busy being thanked by some 150 people there), ended up looking pretty good and the school it went to are very happy:
And here is a short
youtube.com/shorts/AZbsfR1q7-w?feature=share
  • Salrodri
  • Salrodri
04 Feb 2026 23:58 - 05 Feb 2026 00:16
Efinity software reported an error. After reviewing my wiring, I was able to make progress.
I can now connect via JTAG using the Efinity Programmer tool. When I click Start Program, it appears to detect the board, and I receive the message “Device is in user mode.”
At this point, I’m not sure what the next step should be.
I have jumpers W15 and W16 set to UP,UP position so I can attempt an Ethernet connection to 192.168.1.121 However, when I run the following command:
mesaflash --device Ethernet --addr 192.168.1.121 --verbose
No ETHERNET board found
  • PCW
  • PCW's Avatar
04 Feb 2026 23:30
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
Not sure, sounds like the PWM is not setup properly
Can you run your test (where you expect 1V)
and in a terminal type
halcmd show all | grep pwm > pwm.txt
and post pwm.txt here
  • Nkbhvid
  • Nkbhvid
04 Feb 2026 23:11
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Yes
The multimeter gave a jump to 0.5 volt in a glimpse . I don’t know for how long since the meter was set to store highest
I just tried to repeat the test.
This time the 0 was dead 0
Could it have any impact on the result that I also had the 24 v on the enable pin at the same time in the first test?
  • rodw
  • rodw's Avatar
04 Feb 2026 23:09
Replied by rodw on topic Building from source for Trixie
I should mention I show how to build for RIP but you can keep with the Debian way and build the debs and install with sudo dpkg -i on the folder above where you are.
  • rodw
  • rodw's Avatar
04 Feb 2026 23:06
I have done a video on this. There is a bookmark for cloning and compiling.
Master branch build process has been updated but I think there is a typo in the docs. Now getting dependencies is done the debian way with a single command line. This is an amazing improvement :)
  • rodw
  • rodw's Avatar
04 Feb 2026 22:54
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
So I reverted to Dominic's original component cia402.comp based on feedback here so I could get back to basics
Now I have learnt/refreshed my knowledge about ethercat, I used halshow to list all of the lcec pins and noticed the familiar value of 561 but it was on the wrong pin. Checking the XML, I had included a torque pin but there is no PDO or SDO for it (I had tested this earlier with raw ethercat command line commands). So I deleted the entry in my xml. Everything is now mapped correctly. But only Drive/Joint 0 works correctly. lcec and cia402 follow each other but motion only happens on X (Joint/Drive 0)
Joint position/fb follow lcec and cia402 when jogging but for some reason the 3 higher drives don't move.
I've attached the revised XML and my CIA402 hal and ini files. I don't tthink I have mapped anything incorrectly in hal
  • Ismacr63
  • Ismacr63
04 Feb 2026 22:38
Replied by Ismacr63 on topic T3D-L20A-RABF configuration help
Category: Turning
Tomorrow I'll do a new axis configuration to test and compare the hal and ini files again. Would my hal file be correct for normal operation?
  • PCW
  • PCW's Avatar
04 Feb 2026 22:30 - 04 Feb 2026 22:34
Mesa 7i90HD no comunication/ update erprobte on 2nd mesa (Solved)
Yeah, if you just used the seveni90 project you will get a EPP configuration.
if you used the seveni90spi project you will get a SPI configuration and if you used
the seveni90ssrm project you will get a SSerial configuration.
(There is one more 7I90 option: hm2serial)
So unless you made some build error its likely you have loaded EPP configurations
The best way out is probably to get  JTAG programmer, program the FPGA with a working
bitfile with the desired interface and then use mesaflash to restore the EEPROM contents
04 Feb 2026 22:30
Replied by tommylight on topic initramfs-tools error (sudo apt upgrade)
Check the error, does it mention somewhere "raspi" ?
Is this the 2.9.8 version?
04 Feb 2026 22:25
Replied by tommylight on topic Building from source for Trixie
The only 2.10 deb i can find is from buster, so quite old, here
buildbot.linuxcnc.org/dists/buster/maste...reempt/binary-amd64/
  • tar_san
  • tar_san
04 Feb 2026 22:22
I installed from Official LCNC ISO to N150 PC , and right after did this,
sudo apt update sudo apt upgrade
I got error ,
dpkg  initramfs-tools error (--configure):
error exit status 1
My questions are
1) Is it OK to use LCNC in this situation ?
2) Are there any ways to solve this error ?
  • PCW
  • PCW's Avatar
04 Feb 2026 22:15
Do you get near 0V on the analog output
when the 7I97T is powered but LinuxCNC is not running?
Displaying 6766 - 6780 out of 13540 results.
Time to create page: 0.488 seconds
