Hole Spotting
3 months 1 day ago #348320 by dlv
Hole Spotting was created by dlv
I'm reasonably decent at CAD having used Fusion360 to design and 3D print for some time now.  However I'm a newbie (and I mean COMPLETE newbie) to CAM, gcode and post processors.
I've built a 1500x1500mm downdraft plasma CNC table.  It's working rather well.  I've managed to get myself as far as the most basic of understanding manufacturing in Fusion.  Using the PP from the forum here I can get a flat pattern, generate a tool path and post it to an NC file and get parts cut with reasonable success.
I haven't figured out hole spotting though.  I know folks may say use something like Sheetcam and I'm sure it's a good solution but I'm trying to stay in Fusion (for now at least).
I tested QtPlasmaC's built in spotting function by writing a really simple gcode file to spot at the torch's current zeroed position and it works.  The built in spotting is quite nice actually.  Leaves a perfect little dimple (I'm testing with 1/8" aluminum sheet).  500ms pulse@20A
G20          ; Set units to inches G90          ; Absolute distance mode N60 F#<_hal[plasmac.cut-feed-rate]>  ; Copied from other working NC files G0 X0 Y0     ; Torch is already jogged to test location M3 $2 S1     ; Fire spotting tool (triggers the millisecond timer) G91          ; Switch to relative (why?) G1 X0.000001 ; Microscopic move to satisfy LinuxCNC motion controller (why?) M30          ; End program
Before I try to reverse engineer the Fusion360 post processor to figure this out I'm wondering if there's any cool tricks in Fusion to get the PP to write the M3 $2 S1 command at a specific point.
Or as a reasonable work around get it to write something out that's easy to search and replace with M3 $2 S1.   If that makes sense.
I did see something about adding in a drilling operation but when I tried it I discovered the free version of Fusion won't allow that.
Also not sure why the G91/G1microscopic move is necessary.  Pretty sure the tolerance settings will result in it being ignored but without it I get an error loading the file that it'll move outside my machine boundary.  I don't think that's the case but QtPlasmaC still throws the error.
Anyway I hope this isn't a bunch of utterly annoying newbie questions.  :)  I sincerely appreciate any help with this part of the learning curve.
Cheers,
-Dave
3 months 23 hours ago #348323 by rodw
Replied by rodw on topic Hole Spotting
Can't help in fusion but in Sheetcam you can create layers and you can define the minimum diameter of holes you can cut (say 12mm) so you move all of the small holes onto a new layer. When you generate the code for that layer  it will create the spots at the hole centre.
The torch won't fire if there is no movement in the following segment so move to relative coordinates to move a tiny amount to keep LinuxCNC happy and make the torch fire.
So now see if you can translate that to fusion.
3 months 23 hours ago #348324 by tuxcnc
Replied by tuxcnc on topic Hole Spotting
In my opinion using Fusion for plasma (or laser) is like bought truck for drive to church - more troubles than benefits.
My favorite option is Librecad plus dxf2gcode - GPL and cost free.
Try this, even if you will not like them, this is simple and you will easy learn something.
The following user(s) said Thank You: dlv
3 months 23 hours ago #348328 by tommylight
Replied by tommylight on topic Hole Spotting
QtPlasmaC should have a hole spotting/pierce only feature, i am pretty sure i tested that a while back.
www.google.com/search?q=qtplasmac+pierce...tplasmac+pierce+only
3 months 23 hours ago #348329 by rodw
Actually one way to do this would be to write a gcode filter for linuxCNC  that looked for hole below a certain diameter, removed the hole processing and replace it with a spot at the hole centre. Monokrom plasma has a filter that modifies hole processing so perhaps it can help you.
Another really out there possible solution that does not need post processing (but requires master branch) could  be to write a component or modify plasmac.comp and monitor the pin motion.interp.iscircle. When it goes true and motion.interp.arc-radius < minimum hole radius, disable the torch, use external offsets to move a distance of motion.interp.arc-radius along motion.interp.normal-heading (which will be your hole centre), fire the torch to spot, then unwind the offsets to return to where the torch was, let motion take over again then enable the torch when iscircle goes false.(the end of the hole)
3 months 12 hours ago - 3 months 12 hours ago #348345 by dlv
Replied by dlv on topic Hole Spotting
Thanks Rod.  Fusion has cut profiles.  The approach would be similar to the layers you mention I think.  Select the holes to be spotted in one cut profile and the rest of the part sans the small holes in another.  Perhaps a bit more "one click" in Sheetcam but it's really no trouble in Fusion.  Then from the two profiles I post two different NC files so I can change my torch amps between spotting and cutting (I have to do that manually, no fancy Hypertherm for me!).
I will look into writing a gcode filter take small holes and replace with the spotting commands I have in my test code.  That's the approach I've been thinking of anyway.  Was wondering if anyone had already done that.  If there are examples out there of gcode filters anyone can point me at I'd appreciate it.  I've got decent C and Python skills.
Tommy I looked at the feature I think you're referring to and from what I read QtPlasmaC will take a gcode command to only run the pierce operations it finds in the file and no cut ops.  I guess I'd use the cut profile approach above with just the holes in it and set the lead in to put the torch in the hole center for the pierce.  Like 2mm holes with a 1mm 90deg lead in.  Then use this:
Insert #<pierce-only> = 1 into your G-code file prior to the initial cut command to switch the mode on for that specific program run
 So yeah that would be ok if I wanted to actually pierce the hole centers.  I like the "center punch" dimples I'm getting with the M3 command test above but this certainly would be a solution to try and I will.  Might work better on thicker steel.  So far I'm just testing on aluminum sheet.
tuxcnc I'll check out dxf2gcode.  I can export a DXF and post process that.  You're not wrong, Fusion is a beast.  But I'm really quite comfortable on the design side and for the most part I like working with it.  That said since I'm learning the CAM side I am definitely open to trying some alternatives especially if they're open source.
Thanks guys!
Last edit: 3 months 12 hours ago by dlv.
Time to create page: 0.340 seconds
