Timing problem
10 years 9 months ago #68810 by korbendallas78
Timing problem was created by korbendallas78
Hello,
I found a problem with load gmoccapy. I made a gladevcp panel with leds. I connect to this leds some other pins in postgui.hal. With axis ui no problem. But with gmoccap ui is send message : custom_postgui.hal :13: Pin 'leds.hal_led1' does not exist.
This error message not all time. Sometimes gmoccapy is started and the hal leds working well.
I think the custom_postgui.hal loaded before the gmoccapy started.
Sorry for my english.
10 years 9 months ago #68811 by andypugh
Replied by andypugh on topic Timing problem
korbendallas78 wrote: I made a gladevcp panel with leds. I connect to this leds some other pins in postgui.hal. With axis ui no problem. But with gmoccap ui is send message : custom_postgui.hal :13: Pin 'leds.hal_led1' does not exist.
Are you loading the GladeVCP with a "-W" switch?
This is likely to be more a GladeVCP timing issue that Gmoccapy.
loadusr flags are given here:
www.linuxcnc.org/docs/html/man/man1/halcmd.1.html
10 years 9 months ago #68812 by korbendallas78
Replied by korbendallas78 on topic Timing problem
EMBED_TAB_COMMAND = loadusr -W gladevcp -x {XID} leds.glade
10 years 9 months ago - 10 years 9 months ago #68813 by andypugh
korbendallas78 wrote: EMBED_TAB_COMMAND = loadusr -W gladevcp -x {XID} leds.glade
The manual ( www.linuxcnc.org/docs/html/gui/gladevcp.html ) suggests -Wn gladevcp, ie
EMBED_TAB_COMMAND= loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} leds.glade
This waits for a component "gladevcp" and has a -c option that I am not sure of the meaning of, but I think forces a component name, which is possibly useful if it is waiting (-Wn) for a specific component to be ready.
This is a guess, though. No guarantees expressed or implied
Last edit: 10 years 9 months ago by andypugh.
The following user(s) said Thank You: korbendallas78
10 years 9 months ago #68814 by korbendallas78
I tried. Same problem
10 years 9 months ago #68842 by newbynobi
Replied by newbynobi on topic Timing problem
@korbendallas78
I also noticed that behavior some times, I recomend the followingf, as till now it works under all circumstances perferct.
Move all the relevant hal connections from postgui.hal to hal file named leds.hal. That hal file should be in your config dir.
And load your panel like this one:
EMBED_TAB_COMMAND = gladevcp -x {XID} -H leds.hal leds.glade
That command loads the panel and after loading it it connects the hal pin mentioned in the named hal file.
If you need, you can add your own python handler by adding -u led.py
For an example you may look at sim/gmoccapy/gmoccapy-plasma/gmoccapy-plasma.ini
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.208 seconds
