gmoccapy + nativecam
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
17 Sep 2017 10:59 #99050 by tecno
gmoccapy + nativecam was created by tecno
Trying to get Gmoccapy and NativeCam installed but I am obviously doing something wrong.
File Name: gmoccapy_n...ecam.txt
File Size:1 KB
Some errors listed above.
File Name: combimillx...9-17.ini
File Size:5 KB
File Name: combimillx...9-17.hal
File Size:16 KB
Pointers to what to do would be much appreciated
  • tecno
  • Platinum Member
  • Platinum Member
21 Sep 2017 12:38 #99203 by tecno
Replied by tecno on topic gmoccapy + nativecam
Is my question in wrong place/topic as I get no comments?
21 Sep 2017 19:45 #99221 by newbynobi
Replied by newbynobi on topic gmoccapy + nativecam
I do not See errors!
But you habe no configuration of embedded tags in your INI.
Does NativeCam Start stand allown?
Norbert
  • tecno
  • Platinum Member
  • Platinum Member
22 Sep 2017 07:58 #99243 by tecno
Hallo Norbert,
Yes Ncam starts as stand alone.
Re INI I have difficulties to know what is missing.
Bengt
  • tecno
  • Platinum Member
  • Platinum Member
25 Sep 2017 11:57 #99401 by tecno
This how it looks like in my milling machine.
Obviously I have made something wrong, I can run combimillx from Combimill folder.
I can start mill-mm from from 2.7.gmoccapy but not run the mill.
What do I need to do/edit to get all this working? I want to have NCAM in USER TABS = how is this done?
Cheers
Bengt
25 Sep 2017 14:58 #99410 by newbynobi
Please post your complete config folder, i will do the necessary changes for you. Or you just take a look in the documentation, as i did discripe there the needed changes to the ini and hal fles.
Norbert
  • tecno
  • Platinum Member
  • Platinum Member
25 Sep 2017 15:10 #99411 by tecno
How do I copy my *complete* folder? Is it only my Combimill folder or everything?
  • tecno
  • Platinum Member
  • Platinum Member
25 Sep 2017 15:29 #99412 by tecno
File Name: combimill.zip
File Size:41 KB
Could not get archiver to function = got error message. So I made ZIP of my folder here in office.
mfg
Bengt
26 Sep 2017 08:54 #99446 by newbynobi
Hallo Bengt,
please find attached the modified folder. Just copy it to your linuxcnc / configs folder and extract it. After that, go to a terminal and enter linuxcnc followed by ENTER.
Select the new config and watch the terminal for output.
In case the config does not start, just copy the content of the terminal and post it here.
I am not sure, if the copy from my ncam dir does work on your PC too. If you got problems, please delete the ncam folder from the new config folder and do:
To use with your own inifile, it must first be edited. From a normal user terminal, change directory to the one that contains your inifile Using the command : ncam -i(inifilename) -c('mill' | 'plasma' | 'lathe') will automatically create a backup and modify your file. It will also prepare the sub-directory with needed files and links. If you use axis and -t option it will be embedded in a tab
P.S. I am not at home, so i was not able to test with my 7e76e / 7i73 combination.
Norbert
  • tecno
  • Platinum Member
  • Platinum Member
26 Sep 2017 10:41 #99452 by tecno
So far OK that NCAM is in user tab but it is empty
Deleted NCAM dir and try to ncam -i combimillx -c mill but it errors out = see bottom in enclosed text file.
File Name: norbert.txt
File Size:9 KB
Moderators: newbynobi, HansU
Time to create page: 0.316 seconds
