Keyboard functions
8 years 10 months ago #103182 by chopper79
Keyboard functions was created by chopper79
Hello.
I did a quick search and did not find what I was looking for. I am using Gmoccapy for one of my builds and I enabled keyboard shortcuts, but have found that the following key commands do not function.
R = program run
P = program pause
S = program resume
I understand that the gui was designed for touchscreen use, but I like to have a physical keyboard attached as well for easy of functionality. Is there a way to add the above mentioned keyboard shortcut keys to Gmoccapy?
8 years 10 months ago #103198 by newbynobi
Replied by newbynobi on topic Keyboard functions
Hallo,
it is correct, the mentioned shortcuts are not supported.
If there are more people wishing to integrate that features, I will do it.
Otherwise, you will have to change the python code of gmoccapy.
What release of gmoccapy are you using?
Norbert
8 years 10 months ago #103224 by chopper79
Replied by chopper79 on topic Keyboard functions
Thank you for the response.
I am using version that is in master right now. Sorry do not know the version number, just the version bundled with master from 3 weeks ago.
I can attempt to add these in python if you could kindly point me in the right direction of the locations I would need to add the code. Also if you could provide just an example of the code string that I would be adding.
Love the interface also by the way, the more I use it the more it grows on me.
Chop
8 years 10 months ago #103355 by newbynobi
Hallo Chop,
I just uploaded a new testing branch for you.
Please pull:
gmoccapy_additional_keyboard_shortcuts
you should get gmoccapy release 2.3.4:
I introduced new keyboard shortcuts (not case sensitive)
R = run program
P = pause program
S = resume program
This keys will only work in auto mode, not being in edit mode and
a program must be loaded. Pause and resume do only work if a
program is running and / or paused.
If you give me your okay after testing that branch, I will merge that in master.
Norbert
8 years 9 months ago #103966 by newbynobi
Hallo Chop,
have you tested?
Norbert
8 years 9 months ago #103974 by chopper79
Sorry I have not. I have been very busy and I tried to do a pull the other night and I got a return in terminal that there was no gmoccapy_additional_keyboard_shortcuts to pull. So I went to github and did not find it as well. I am sure I am doing something wrong on the pull as this would be the first time I have used github to pull something.
This is something that I am still very interested in testing, just could not get it pulled to test.
Moderators: newbynobi, HansU
Time to create page: 0.402 seconds
