Jog Axis no Function by last update
  • Weiler810T
  • Weiler810T's Avatar Topic Author
  • Visitor
  • Visitor
11 Aug 2018 09:21 #115879 by Weiler810T
Jog Axis no Function by last update was created by Weiler810T
Helo
When I press the X or Y or Z-button in manualmode, says linuxcnc
wrong motion mode ?:(
The error came only with the last update, before the machine ran perfectly
**** GMOCCAPY INFO : postgui halfile = gmoccapy_postgui.hal ****:
Emit interp-run
1 2
MANUAL Mode
Emit interp-run
wrong motion mode, change to the correct one
Last update
LINUXCNC - 2.8.0-pre1-3813-g42d0b443d
Machine configuration directory is '/home/chiron/linuxcnc/configs/ChironFZ16'
Machine configuration file is 'chiron.ini'
Starting LinuxCNC...
Found file(REL): ./hm2-servo.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i20 at 0000:05:01.0
Linuxcnc
Kernel message information:
[    0.000000] microcode: microcode updated early to revision 0xd0, date = 2010-09-30
[    0.000000] Linux version 4.9.0-7-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-1 (2018-07-05)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-7-rt-amd64 root=UUID=f6ce28d2-210d-401d-98ce-26bd6dd63be4 ro quiet
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] e820: BIOS-provided physical RAM map:
My old Config. Axis2.5.4 and Gmoccapy 2.7.12 works fine, no Probs
Any idea ?
11 Aug 2018 12:10 #115881 by newbynobi
Replied by newbynobi on topic Jog Axis no Function by last update
Gmoccapy in master do support the new feature joint axis mode, so you need to adapt your config.
What happen after homing the machine?
Norbert
  • Weiler810T
  • Visitor
  • Visitor
11 Aug 2018 15:41 #115891 by Weiler810T
Replied by Weiler810T on topic Jog Axis no Function by last update
Hallo Norbert
The new feature joint axis mode was already adapted beforehand.
After honimg Maschine is the same Proplem in manualmode, the jogwheel works though.
I can move all axes with the jogwheel in maualmode, but the jog-button no funktion.
11 Aug 2018 16:02 #115893 by newbynobi
Please test with sim machine and report, if the sim machine do work, post your config, so I can check on that one.
Norbert
  • Weiler810T
  • Visitor
  • Visitor
12 Aug 2018 04:50 #115943 by Weiler810T
Hallo Norbert
Sim works in manual mode :unsure:
Here is my Config.
File Name: ChironFZ16...1.tar.gz
File Size:287 KB
Siggi
  • Weiler810T
  • Visitor
  • Visitor
15 Aug 2018 09:08 #116072 by Weiler810T
I have the last update and the machine will not start up anymore :( :blink:
Somebody was fiddling with fucking bloody :angry: Glade
Is the same old Config,I only recorded the update LINUXCNC - 2.8.0-pre1-3817-g7aa9e98
**** GMOCCAPY INFO ****
**** btn_zero_g92 wurde mit btn_block_height ersetzt. ****
**** found valid probe config in INI File ****
**** will use auto tool measurement ****
**** GMOCCAPY INFO: Gcode.lang found ****
**** GMOCCAPY INFO : inifile = /home/chiron/linuxcnc/configs/ChironFZ16/chiron.ini ****:
gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py
Killing task linuxcncsvr, PID=9100
Killing task milltask, PID=9209
task: 192 cycles, min=0.000016, max=0.012585, avg=0.009076, 0 latency excursions (> 10x expected cycle time of 0.010000s)
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
****  probe_screen GETINIINFO ****
 Preference file path: /home/chiron/linuxcnc/configs/ChironFZ16/HM2-Servo.pref
Xlib.protocol.request.QueryExtension
ERROR:  Can't remove RTAI modules, kill the following process(es) first
  9226Removing NML shared memory segments
Debug file information:
(gmoccapy:9213): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed
gmoccapy_postgui.hal:40: Pin 'gladevcp.hal_mtk' does not exist
  File "/usr/bin/gladevcp", line 45, in <module>
    import gladevcp.makepins
  File "/usr/lib/pymodules/python2.7/gladevcp/__init__.py", line 67, in <module>
    importlib.import_module(modname)
  File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
    __import__(name)
  File "/usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py", line 8, in <module>
    Copyright © 2012 Nick Drobchenko aka Nick from cnc-club.ru'''
KeyboardInterrupt
X protocol error:
<class 'Xlib.error.BadWindow'>: code = 3, resource_id = Xlib.xobject.resource.Resource(0x04e00043), sequence_number = 11, major_opcode = 7, minor_opcode = 0
9100
  PID TTY      STAT   TIME COMMAND
9209
Stopping realtime threads
Unloading hal components
  File "/usr/lib/pymodules/python2.7/gladevcp/led.py", line 74, in expose
    def expose(self, widget, event):
KeyboardInterrupt
                     USER        PID ACCESS COMMAND
/dev/rtai_shm:       chiron    ....m gladevcp
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
15 Aug 2018 09:45 - 15 Aug 2018 09:48 #116073 by newbynobi
Hallo,
this is the relevant error:
If this pin is a part of a embedded panel, you will need to load / connect that pin within the glade hal file, while loading the panel.
Like you do with other panels, i.e.
gladevcp -x {XID} -H Weiler_810T_panel.hal Weiler_810T.glade
What is this pin for?
Norbert
Last edit: 15 Aug 2018 09:48 by newbynobi.
  • Weiler810T
  • Visitor
  • Visitor
15 Aug 2018 11:23 - 15 Aug 2018 14:15 #116078 by Weiler810T
Hallo Norbert
The pin is for messtaster,but at the last 1000 updates works
# Name of display program, e.g., tkemc
DISPLAY =              gmoccapy
EMBED_TAB_NAME = Weiler_810T
EMBED_TAB_LOCATION = box_right
EMBED_TAB_COMMAND = gladevcp -x {XID} -H Weiler_810T_panel.hal Weiler_810T.glade
DEFAULT_SPINDLE_SPEED = 150
# PREFERENCE_FILE_PATH = /home/chiron/linuxcnc/configs/ChironFZ16/gmoccapy.pref
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_LOCATION = ntb_user_tabs
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
####  Renishaw Messtaster ########
#net probe-in1     debounce.0.5.in <= hm2_5i20.1.gpio.051.in
#net probe-in      debounce.0.5.out =>  motion.probe-input => gladevcp.hal_mtk
net probe-in     hm2_5i20.1.gpio.051.in =>  motion.probe-input => gladevcp.hal_mtk
net probe-err      hm2_5i20.1.gpio.052.in_not => gladevcp.hal_mtk
net probe-bat    hm2_5i20.1.gpio.053.in => gladevcp.hal_mtb
# net renishaw    hm2_5i20.1.gpio.055.in
File Name: probe_screen.glade
File Size:143 KB
File Name: probe_screen.py
File Size:63 KB
gladevcp.hal_mtk > Kontakt
gladevcp.hal_mtk > Status
gladevcp.hal_mtb > Batterie
Siggi
Last edit: 15 Aug 2018 14:15 by Weiler810T.
15 Aug 2018 16:03 #116084 by newbynobi
Hallo,
than that one is a race conflict.
Do not connect Hal Pins of Glade embedded Panel in the postgui.hal file, as some Glade Panel are loaded completely after the GUI, thats why you should add an Hal file to the embedded tab.
Norbert
  • Weiler810T
  • Visitor
  • Visitor
18 Aug 2018 09:47 #116236 by Weiler810T
Servus Norbert
Irgendwas beißt sich da in den Hintern :(
Starten mit probe_screen.pins in der gmoccappy.hal
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
(gmoccapy:2722): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
gmoccapy_postgui.hal:23: Pin 'probe_screen.hal_mtk' does not exist
  File "/usr/lib/python2.7/dist-packages/gladevcp/__init__.py", line 1, in <module>
  File "/usr/bin/gladevcp", line 312, in <module>
    main()
  File "/usr/bin/gladevcp", line 221, in main
    window = xembed.reparent(window, opts.parent)
  File "/usr/lib/python2.7/dist-packages/gladevcp/xembed.py", line 22, in reparent
    from hal_pythonplugin import *
  File "/usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py", line 22, in <module>
    d = display.Display()
  File "/usr/lib/python2.7/dist-packages/Xlib/display.py", line 80, in __init__
    from combi_dro import Combi_DRO
  File "/usr/lib/python2.7/dist-packages/gladevcp/combi_dro.py", line 20, in <module>
    self.display = _BaseDisplay(display)
  File "/usr/lib/python2.7/dist-packages/Xlib/display.py", line 62, in __init__
    display.Display.__init__(*(self, ) + args, **keys)
  File "/usr/lib/python2.7/dist-packages/Xlib/protocol/display.py", line 125, in __init__
    import gtk
KeyboardInterrupt
    auth_prot_data = auth_data)
  File "/usr/lib/python2.7/dist-packages/Xlib/protocol/display.py", line 991, in __init__
    display.send_and_recv(request = -1)
  File "/usr/lib/python2.7/dist-packages/Xlib/protocol/display.py", line 511, in send_and_recv
    rs, ws, es = select.select([self.socket], writeset, [], timeout)
KeyboardInterrupt
2646
2718
 2718 ?        D      0:00 milltask -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
RTAPI_PCI: Unmapped 65536 bytes at 0x7fae8dcf1000
RTAPI_PCI: Unmapped 65536 bytes at 0x7fae8dce1000
Starten mit einer probe_screen.hal
./probe_screen.hal:8: Pin 'probe_screen.hal_mtk' does not exist
2893
RTAPI_PCI: Unmapped 65536 bytes at 0x7fb2f4ef0000
RTAPI_PCI: Unmapped 65536 bytes at 0x7fb2f4ee0000
Wenn ich ohne probe_screen.hal starte, startet Gmoccappy und die die probe_screen pins sind vorhanden.
File Name: probe_screen.hal
File Size:0 KB
Any idea ?
Moderators: newbynobi, HansU
Time to create page: 0.327 seconds
