Persitant Error
- islander261
- Thank you received: 216
07 Jun 2019 03:34 #136162
by islander261
Persitant Error was created by islander261
Hello
Can anyone help? I've had this error with every instance of Gmoccapy I have installed over the last 3 years. From starting in a terminal as I always do.
(gmoccapy:4344): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failedJohn
- pl7i92
- Thank you received: 358
07 Jun 2019 05:25 #136170
by pl7i92
Replied by pl7i92 on topic Persitant Error
that seams a mousepad problem
did you install gedit as well
and use in ini gedit
or if gedit is the editor try to use mousepad
Display section
EDITOR = gedit
Display section
EDITOR = gedit
- islander261
07 Jun 2019 16:25 #136213
by islander261
Replied by islander261 on topic Persitant Error
Changing or omitting the editor in the .ini file has no effect on the error.
- pl7i92
07 Jun 2019 16:36 #136216
by pl7i92
did you try to get the latest gtksourceview lib from the Distro
- islander261
07 Jun 2019 16:44 #136223
by islander261
Fresh 2.9 clone one day ago.
- pl7i92
07 Jun 2019 16:47 #136226
by pl7i92
can you provide your ini and hal so i can check that here
maybe if you can go with the Whole packed Mashine Folder
ZIP
ZIP
- islander261
07 Jun 2019 18:37 #136242
by islander261
I doubt this will have much bearing on the subject. I have had this problem for over three years, 2.7, 2.8, 2.9.
- Thank you received: 2181
07 Jun 2019 19:04 #136244
Replied by cmorley on topic Persitant Error
It seems it is safe to ignore.
Chris M
Chris M
- islander261
07 Jun 2019 19:36 #136245
by islander261
Chris
I have been ignoring it for 3 years now! Now that I have the Plasmac branch running so well I was hoping to get rid of this niggly error and have configuration that starts with no errors.
07 Jun 2019 19:50 #136246
This undoubtedly is a problem related to hal_sourceview - it sets up markup for Gcode colors etc.
Looks like maybe a search path is not set or initialized properly.
If it's really important to you please make a formal bug report here:
github.com/LinuxCNC/linuxcnc/issues
Chris M
Chris M
Moderators: newbynobi, HansU
Time to create page: 0.169 seconds
