Motion feed hold cycle start physical buttons
7 years 2 months ago #143681 by Toolman321
i have no idea why but when i try to add the code containing and2.0 i get an error
ive added the debug file information below if anyone can help me please
many thanks
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.14 Machine configuration directory is '/home/lee/linuxcnc/configs/lee' Machine configuration file is 'lee.ini' INIFILE=/home/lee/linuxcnc/configs/lee/lee.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=gmoccapy Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./lee.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=3739 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: . HAL: ERROR: function 'and2.0' not found ./lee.hal:24: addf failed 3739 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable) [ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e6000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 00000000df6a0000 (usable) [ 0.000000] BIOS-e820: 00000000df6a0000 - 00000000df6b0000 (ACPI data) [ 0.000000] BIOS-e820: 00000000df6b0000 - 00000000df6e0000 (ACPI NVS) [ 0.000000] BIOS-e820: 00000000df6e0000 - 00000000e0000000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000ff380000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 0000000120000000 (usable) [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU! [ 0.000000] SMBIOS 2.6 present. [ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./AD425PV3, BIOS P1.20 04/01/2011 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0xdf6a0 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CFFFF write-protect [ 0.000000] D0000-DFFFF uncachable [ 0.000000] E0000-EFFFF write-through [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F00000000 write-back [ 0.000000] 1 base 100000000 mask FE0000000 write-back [ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable [ 0.000000] 3 base 0DF700000 mask FFFF00000 uncachable [ 0.000000] 4 base 0DF800000 mask FFF800000 uncachable [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000df700000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] found SMP MP-table at [c00ff780] ff780 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 36526000 - 3728b000 [ 0.000000] ACPI: RSDP 000f9ca0 00014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT df6a0000 0003C (v01 040111 RSDT1620 20110401 MSFT 00000097) [ 0.000000] ACPI: FACP df6a0200 00084 (v01 040111 FACP1620 20110401 MSFT 00000097) [ 0.000000] ACPI: DSDT df6a0440 04DB7 (v01 AS459 AS459111 00000111 INTL 20051117) [ 0.000000] ACPI: FACS df6b0000 00040 [ 0.000000] ACPI: APIC df6a0390 0006C (v01 040111 APIC1620 20110401 MSFT 00000097) [ 0.000000] ACPI: MCFG df6a0400 0003C (v01 040111 OEMMCFG 20110401 MSFT 00000097) [ 0.000000] ACPI: OEMB df6b0040 00082 (v01 040111 OEMB1620 20110401 MSFT 00000097) [ 0.000000] ACPI: AAFT df6aa440 00027 (v01 040111 OEMAAFT 20110401 MSFT 00000097) [ 0.000000] ACPI: GSCI df6b00d0 02024 (v01 040111 GMCHSCI 20110401 MSFT 00000097) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 2686MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x000df6a0 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x000df6a0 [ 0.000000] On node 0 totalpages: 914991 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4936200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 5374 pages used for memmap [ 0.000000] HighMem zone: 682404 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e6000 [ 0.000000] PM: Registered nosave memory: 00000000000e6000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at e0000000 (gap: e0000000:1ee00000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 907841 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=677d2c16-1db4-4bb8-a586-57c581ffdf43 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 7320704 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:000df6a0) [ 0.000000] Memory: 3603480k/3660416k available (3495k kernel code, 56484k reserved, 1237k data, 416k init, 2751112k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:712 16 [ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 1795.077 MHz processor. [ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 3590.15 BogoMIPS (lpj=7180308) [ 0.004015] pid_max: default: 32768 minimum: 301 [ 0.004127] Security Framework initialized [ 0.004136] AppArmor: AppArmor disabled by boot time parameter [ 0.004182] Mount-cache hash table entries: 512 [ 0.008148] Initializing cgroup subsys cpuacct [ 0.008156] Initializing cgroup subsys memory [ 0.008174] Initializing cgroup subsys devices [ 0.008180] Initializing cgroup subsys freezer [ 0.008186] Initializing cgroup subsys net_cls [ 0.008191] Initializing cgroup subsys blkio [ 0.008206] Initializing cgroup subsys perf_event [ 0.008263] CPU: Physical Processor ID: 0 [ 0.008268] CPU: Processor Core ID: 0 [ 0.008273] mce: CPU supports 5 MCE banks [ 0.008286] CPU0: Thermal monitoring enabled (TM1) [ 0.008362] ACPI: Core revision 20120320 [ 0.016107] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.016499] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.058572] CPU0: Intel(R) Atom(TM) CPU D425 @ 1.80GHz stepping 0a [ 0.060003] Performance Events: PEBS fmt0+, 8-deep LBR, Atom events, Intel PMU driver. [ 0.060003] ... version: 3 [ 0.060003] ... bit width: 40 [ 0.060003] ... generic registers: 2 [ 0.060003] ... value mask: 000000ffffffffff [ 0.060003] ... max period: 000000007fffffff [ 0.060003] ... fixed-purpose events: 3 [ 0.060003] ... event mask: 0000000700000003 [ 0.068148] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.080054] CPU 1 irqstacks, hard=f3cd4000 soft=f3cd6000 [ 0.080060] Booting Node 0, Processors #1 [ 0.008000] Initializing CPU#1 [ 0.008000] Disabled fast string operations [ 0.092069] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.092166] Brought up 2 CPUs [ 0.092175] Total of 2 processors activated (7180.30 BogoMIPS). [ 0.092615] devtmpfs: initialized [ 0.092615] PM: Registering ACPI NVS region [mem 0xdf6b0000-0xdf6dffff] (196608 bytes) [ 0.092615] dummy: [ 0.092615] NET: Registered protocol family 16 [ 0.092754] ACPI: bus type pci registered [ 0.092894] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.092902] PCI: not using MMCONFIG [ 0.093295] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=2 [ 0.093301] PCI: Using configuration type 1 for base access [ 0.097093] bio: create slab <bio-0> at 0 [ 0.097093] ACPI: Added _OSI(Module Device) [ 0.097093] ACPI: Added _OSI(Processor Device) [ 0.097093] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.097093] ACPI: Added _OSI(Processor Aggregator Device) [ 0.100854] ACPI: EC: Look up EC in DSDT [ 0.104872] ACPI: Executed 1 blocks of module-level executable AML code [ 0.111769] ACPI: Interpreter enabled [ 0.111788] ACPI: (supports S0 S1 S4 S5) [ 0.111846] ACPI: Using IOAPIC for interrupt routing [ 0.111913] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.116322] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources [ 0.116329] PCI: Using MMCONFIG for extended config space [ 0.130720] ACPI: No dock devices found. [ 0.130734] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.131366] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.131808] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] [ 0.131817] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.131825] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.131832] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff] [ 0.131839] pci_root PNP0A08:00: host bridge window [mem 0xdf700000-0xf7ffffff] [ 0.131846] pci_root PNP0A08:00: host bridge window [mem 0xfc000000-0xfed8ffff] [ 0.131938] PCI host bridge to bus 0000:00 [ 0.131946] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.131953] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.131960] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.131967] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff] [ 0.131974] pci_bus 0000:00: root bus resource [mem 0xdf700000-0xf7ffffff] [ 0.131981] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed8ffff] [ 0.132023] pci 0000:00:00.0: [8086:a000] type 00 class 0x060000 [ 0.132094] pci 0000:00:02.0: [8086:a001] type 00 class 0x030000 [ 0.132114] pci 0000:00:02.0: reg 10: [mem 0xfe980000-0xfe9fffff] [ 0.132127] pci 0000:00:02.0: reg 14: [io 0xdc00-0xdc07] [ 0.132139] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff pref] [ 0.132151] pci 0000:00:02.0: reg 1c: [mem 0xfe800000-0xfe8fffff] [ 0.132244] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300 [ 0.132268] pci 0000:00:1b.0: reg 10: [mem 0xfe978000-0xfe97bfff 64bit] [ 0.132343] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.132382] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400 [ 0.132458] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.132499] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300 [ 0.132553] pci 0000:00:1d.0: reg 20: [io 0xd880-0xd89f] [ 0.132600] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300 [ 0.132654] pci 0000:00:1d.1: reg 20: [io 0xd800-0xd81f] [ 0.132699] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300 [ 0.132752] pci 0000:00:1d.2: reg 20: [io 0xd480-0xd49f] [ 0.132799] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300 [ 0.132853] pci 0000:00:1d.3: reg 20: [io 0xd400-0xd41f] [ 0.132908] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320 [ 0.132935] pci 0000:00:1d.7: reg 10: [mem 0xfe977c00-0xfe977fff] [ 0.133024] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.133058] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401 [ 0.133141] pci 0000:00:1f.0: [8086:27bc] type 00 class 0x060100 [ 0.133238] pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared [ 0.133288] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018a [ 0.133310] pci 0000:00:1f.2: reg 10: [io 0x0000-0x0007] [ 0.133324] pci 0000:00:1f.2: reg 14: [io 0x0000-0x0003] [ 0.133338] pci 0000:00:1f.2: reg 18: [io 0x0000-0x0007] [ 0.133353] pci 0000:00:1f.2: reg 1c: [io 0x0000-0x0003] [ 0.133367] pci 0000:00:1f.2: reg 20: [io 0xff90-0xff9f] [ 0.133381] pci 0000:00:1f.2: reg 24: [mem 0x00000000-0x000003ff] [ 0.133416] pci 0000:00:1f.2: PME# supported from D3hot [ 0.133441] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500 [ 0.133505] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f] [ 0.133626] pci 0000:01:00.0: [1969:1083] type 00 class 0x020000 [ 0.133659] pci 0000:01:00.0: reg 10: [mem 0xfeac0000-0xfeafffff 64bit] [ 0.133678] pci 0000:01:00.0: reg 18: [io 0xec00-0xec7f] [ 0.133776] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.140039] pci 0000:00:1c.0: PCI bridge to [bus 01-01] [ 0.140049] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff] [ 0.140058] pci 0000:00:1c.0: bridge window [mem 0xfea00000-0xfeafffff] [ 0.140108] pci 0000:02:00.0: [2718:5125] type 00 class 0x110000 [ 0.140130] pci 0000:02:00.0: reg 10: [mem 0xfebf0000-0xfebfffff] [ 0.140250] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode) [ 0.140262] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.140274] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.140281] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.140289] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.140296] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode) [ 0.140304] pci 0000:00:1e.0: bridge window [mem 0xdf700000-0xf7ffffff] (subtractive decode) [ 0.140311] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfed8ffff] (subtractive decode) [ 0.140330] pci_bus 0000:00: on NUMA node 0 [ 0.140340] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.140620] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.140854] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT] [ 0.141391] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.150347] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 *10 11 12 14 15) [ 0.150501] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled. [ 0.150655] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 7 10 11 12 14 15) [ 0.150804] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 10 11 12 14 15) [ 0.150954] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled. [ 0.151106] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *10 11 12 14 15) [ 0.151256] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled. [ 0.151408] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 *11 12 14 15) [ 0.151566] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.151566] vgaarb: loaded [ 0.151566] vgaarb: bridge control possible 0000:00:02.0 [ 0.151566] PCI: Using ACPI for IRQ routing [ 0.151566] PCI: pci_cache_line_size set to 64 bytes [ 0.151566] Expanded resource reserved due to conflict with PCI Bus 0000:00 [ 0.151566] reserve RAM buffer: 000000000009f800 - 000000000009ffff [ 0.151566] reserve RAM buffer: 00000000df6a0000 - 00000000dfffffff [ 0.152349] pnp: PnP ACPI init [ 0.152378] ACPI: bus type pnp registered [ 0.152657] pnp 00:00: [bus 00-ff] [ 0.152666] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.152673] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.152679] pnp 00:00: [io 0x0d00-0xffff window] [ 0.152686] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.152693] pnp 00:00: [mem 0x000d0000-0x000dffff window] [ 0.152700] pnp 00:00: [mem 0xdf700000-0xf7ffffff window] [ 0.152707] pnp 00:00: [mem 0xfc000000-0xfed8ffff window] [ 0.152821] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.152853] pnp 00:01: [mem 0xfed14000-0xfed19fff] [ 0.152860] pnp 00:01: [mem 0xfed90000-0xfed93fff] [ 0.152953] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved [ 0.152962] system 00:01: [mem 0xfed90000-0xfed93fff] has been reserved [ 0.152971] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.153068] pnp 00:02: [dma 4] [ 0.153075] pnp 00:02: [io 0x0000-0x000f] [ 0.153082] pnp 00:02: [io 0x0081-0x0083] [ 0.153088] pnp 00:02: [io 0x0087] [ 0.153093] pnp 00:02: [io 0x0089-0x008b] [ 0.153099] pnp 00:02: [io 0x008f] [ 0.153105] pnp 00:02: [io 0x00c0-0x00df] [ 0.153174] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.153215] pnp 00:03: [io 0x0070-0x0071] [ 0.153234] pnp 00:03: [irq 8] [ 0.153303] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.153333] pnp 00:04: [io 0x0061] [ 0.153396] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.153427] pnp 00:05: [io 0x00f0-0x00ff] [ 0.153440] pnp 00:05: [irq 13] [ 0.153504] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.155263] pnp 00:06: [io 0x0378-0x037f] [ 0.155270] pnp 00:06: [io 0x0778-0x077f] [ 0.155284] pnp 00:06: [irq 7] [ 0.155290] pnp 00:06: [dma 3] [ 0.155705] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active) [ 0.155946] pnp 00:07: [io 0x0010-0x001f] [ 0.155954] pnp 00:07: [io 0x0022-0x003f] [ 0.155960] pnp 00:07: [io 0x0044-0x005f] [ 0.155966] pnp 00:07: [io 0x0062-0x0063] [ 0.155972] pnp 00:07: [io 0x0065-0x006f] [ 0.155978] pnp 00:07: [io 0x0072-0x007f] [ 0.155983] pnp 00:07: [io 0x0080] [ 0.155989] pnp 00:07: [io 0x0084-0x0086] [ 0.155996] pnp 00:07: [io 0x0088] [ 0.156019] pnp 00:07: [io 0x008c-0x008e] [ 0.156025] pnp 00:07: [io 0x0090-0x009f] [ 0.156031] pnp 00:07: [io 0x00a2-0x00bf] [ 0.156037] pnp 00:07: [io 0x00e0-0x00ef] [ 0.156043] pnp 00:07: [io 0x04d0-0x04d1] [ 0.156049] pnp 00:07: [io 0x0800-0x087f] [ 0.156056] pnp 00:07: [io 0x0000-0xffffffff disabled] [ 0.156062] pnp 00:07: [io 0x0480-0x04bf] [ 0.156068] pnp 00:07: [mem 0xfed1c000-0xfed1ffff] [ 0.156075] pnp 00:07: [mem 0xfed20000-0xfed8ffff] [ 0.156194] system 00:07: [io 0x04d0-0x04d1] has been reserved [ 0.156203] system 00:07: [io 0x0800-0x087f] has been reserved [ 0.156211] system 00:07: [io 0x0480-0x04bf] has been reserved [ 0.156220] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.156228] system 00:07: [mem 0xfed20000-0xfed8ffff] has been reserved [ 0.156237] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.156482] pnp 00:08: [mem 0xffb80000-0xffbfffff] [ 0.156490] pnp 00:08: [mem 0xfff80000-0xffffffff] [ 0.156564] pnp 00:08: Plug and Play ACPI device, IDs INT0800 (active) [ 0.156697] pnp 00:09: [mem 0xffc00000-0xfff7ffff] [ 0.156800] system 00:09: [mem 0xffc00000-0xfff7ffff] has been reserved [ 0.156810] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.157085] pnp 00:0a: [io 0x0060] [ 0.157092] pnp 00:0a: [io 0x0064] [ 0.157099] pnp 00:0a: [mem 0xfec00000-0xfec00fff] [ 0.157105] pnp 00:0a: [mem 0xfee00000-0xfee00fff] [ 0.157214] system 00:0a: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.157223] system 00:0a: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.157232] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.158067] pnp 00:0b: [io 0x03f8-0x03ff] [ 0.158083] pnp 00:0b: [irq 4] [ 0.158090] pnp 00:0b: [dma 0 disabled] [ 0.158277] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.158547] pnp 00:0c: [io 0x0000-0xffffffff disabled] [ 0.158555] pnp 00:0c: [io 0x0280-0x028f] [ 0.158561] pnp 00:0c: [io 0x0290-0x029f] [ 0.158668] system 00:0c: [io 0x0280-0x028f] has been reserved [ 0.158677] system 00:0c: [io 0x0290-0x029f] has been reserved [ 0.158686] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.158793] pnp 00:0d: [mem 0xf8000000-0xfbffffff] [ 0.158895] system 00:0d: [mem 0xf8000000-0xfbffffff] has been reserved [ 0.158905] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.159404] pnp 00:0e: [mem 0x00000000-0x0009ffff] [ 0.159412] pnp 00:0e: [mem 0x000c0000-0x000cffff] [ 0.159418] pnp 00:0e: [mem 0x000e0000-0x000fffff] [ 0.159425] pnp 00:0e: [mem 0x00100000-0xdf6fffff] [ 0.159435] pnp 00:0e: [mem 0xfed90000-0xffffffff] [ 0.159555] system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.159565] system 00:0e: [mem 0x000c0000-0x000cffff] could not be reserved [ 0.159573] system 00:0e: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.159582] system 00:0e: [mem 0x00100000-0xdf6fffff] could not be reserved [ 0.159590] system 00:0e: [mem 0xfed90000-0xffffffff] could not be reserved [ 0.159600] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.160028] pnp: PnP ACPI: found 15 devices [ 0.160034] ACPI: ACPI bus type pnp unregistered [ 0.160041] PnPBIOS: Disabled by ACPI PNP [ 0.200088] Switching to clocksource acpi_pm [ 0.200164] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000 [ 0.200190] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.200204] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref] [ 0.200214] pci 0000:00:1f.2: BAR 5: assigned [mem 0xf0200000-0xf02003ff] [ 0.200227] pci 0000:00:1c.0: PCI bridge to [bus 01-01] [ 0.200235] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff] [ 0.200245] pci 0000:00:1c.0: bridge window [mem 0xfea00000-0xfeafffff] [ 0.200254] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf01fffff 64bit pref] [ 0.200266] pci 0000:00:1e.0: PCI bridge to [bus 02-02] [ 0.200276] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.200330] pci 0000:00:1e.0: setting latency timer to 64 [ 0.200339] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.200346] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.200353] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.200360] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff] [ 0.200367] pci_bus 0000:00: resource 8 [mem 0xdf700000-0xf7ffffff] [ 0.200373] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfed8ffff] [ 0.200380] pci_bus 0000:01: resource 0 [io 0xe000-0xefff] [ 0.200387] pci_bus 0000:01: resource 1 [mem 0xfea00000-0xfeafffff] [ 0.200394] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref] [ 0.200402] pci_bus 0000:02: resource 1 [mem 0xfeb00000-0xfebfffff] [ 0.200408] pci_bus 0000:02: resource 4 [io 0x0000-0x0cf7] [ 0.200415] pci_bus 0000:02: resource 5 [io 0x0d00-0xffff] [ 0.200422] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff] [ 0.200428] pci_bus 0000:02: resource 7 [mem 0x000d0000-0x000dffff] [ 0.200435] pci_bus 0000:02: resource 8 [mem 0xdf700000-0xf7ffffff] [ 0.200442] pci_bus 0000:02: resource 9 [mem 0xfc000000-0xfed8ffff] [ 0.200639] NET: Registered protocol family 2 [ 0.200794] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.201205] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.202066] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.202467] TCP: Hash tables configured (established 131072 bind 65536) [ 0.202473] TCP: reno registered [ 0.202483] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.202502] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.202772] NET: Registered protocol family 1 [ 0.202811] pci 0000:00:02.0: Boot video device [ 0.203048] PCI: CLS 32 bytes, default 64 [ 0.203166] Unpacking initramfs... [ 0.781174] Freeing initrd memory: 13716k freed [ 0.791744] audit: initializing netlink socket (disabled) [ 0.791782] type=2000 audit(1567191191.788:1): initialized [ 0.815275] highmem bounce pool size: 64 pages [ 0.815288] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.815855] VFS: Disk quotas dquot_6.5.2 [ 0.815928] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.816157] msgmni has been set to 1691 [ 0.816586] alg: No test for stdrng (krng) [ 0.816669] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.816678] io scheduler noop registered [ 0.816683] io scheduler deadline registered [ 0.816740] io scheduler cfq registered (default) [ 0.817032] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.817076] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.817082] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.817839] GHES: HEST is not enabled! [ 0.817869] isapnp: Scanning for PnP cards... [ 1.171764] isapnp: No Plug & Play device found [ 1.171920] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.192319] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.213418] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.213811] Linux agpgart interface v0.103 [ 1.214036] agpgart-intel 0000:00:00.0: Intel GMA3150 Chipset [ 1.214207] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable [ 1.214418] agpgart-intel 0000:00:00.0: detected 8192K stolen memory [ 1.214640] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000 [ 1.214945] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.217338] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.217373] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.217728] mousedev: PS/2 mouse device common for all mice [ 1.217805] rtc_cmos 00:03: RTC can wake from S4 [ 1.218022] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 1.218057] rtc0: alarms up to one month, y3k, 114 bytes nvram [ 1.218327] TCP: cubic registered [ 1.218496] NET: Registered protocol family 10 [ 1.218987] Mobile IPv6 [ 1.218995] NET: Registered protocol family 17 [ 1.219008] Registering the dns_resolver key type [ 1.219112] Using IPI No-Shortcut mode [ 1.219444] PM: Hibernation image not present or could not be loaded. [ 1.219474] registered taskstats version 1 [ 1.220149] rtc_cmos 00:03: setting system clock to 2019-08-30 18:53:12 UTC (1567191192) [ 1.220374] Freeing unused kernel memory: 416k freed [ 1.220751] Write protecting the kernel text: 3496k [ 1.220808] Write protecting the kernel read-only data: 984k [ 1.250353] udevd[49]: starting version 175 [ 1.291875] usbcore: registered new interface driver usbfs [ 1.291956] usbcore: registered new interface driver hub [ 1.304136] usbcore: registered new device driver usb [ 1.305440] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.305602] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 1.305617] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 1.305706] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 1.305758] ehci_hcd 0000:00:1d.7: using broken periodic workaround [ 1.305782] ehci_hcd 0000:00:1d.7: debug port 1 [ 1.331415] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 1.331479] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe977c00 [ 1.343788] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 1.343916] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.343928] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.343939] usb usb1: Product: EHCI Host Controller [ 1.343947] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 1.343956] usb usb1: SerialNumber: 0000:00:1d.7 [ 1.344439] hub 1-0:1.0: USB hub found [ 1.344464] hub 1-0:1.0: 8 ports detected [ 1.345704] uhci_hcd: USB Universal Host Controller Interface driver [ 1.345827] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 1.345839] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 1.345876] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 1.345928] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000d880 [ 1.346056] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.346067] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.346076] usb usb2: Product: UHCI Host Controller [ 1.346085] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.346094] usb usb2: SerialNumber: 0000:00:1d.0 [ 1.354536] hub 2-0:1.0: USB hub found [ 1.354556] hub 2-0:1.0: 2 ports detected [ 1.354854] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 1.354866] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 1.354897] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 1.354990] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d800 [ 1.355112] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.355123] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.355132] usb usb3: Product: UHCI Host Controller [ 1.355141] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.355150] usb usb3: SerialNumber: 0000:00:1d.1 [ 1.361219] hub 3-0:1.0: USB hub found [ 1.361243] hub 3-0:1.0: 2 ports detected [ 1.361540] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 1.361552] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 1.361583] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 1.361676] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d480 [ 1.364546] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.364559] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.364569] usb usb4: Product: UHCI Host Controller [ 1.364578] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.364587] usb usb4: SerialNumber: 0000:00:1d.2 [ 1.364984] hub 4-0:1.0: USB hub found [ 1.365004] hub 4-0:1.0: 2 ports detected [ 1.365302] uhci_hcd 0000:00:1d.3: setting latency timer to 64 [ 1.365314] uhci_hcd 0000:00:1d.3: UHCI Host Controller [ 1.365349] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5 [ 1.365432] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000d400 [ 1.365550] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.365561] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.365570] usb usb5: Product: UHCI Host Controller [ 1.365578] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.365586] usb usb5: SerialNumber: 0000:00:1d.3 [ 1.368650] hub 5-0:1.0: USB hub found [ 1.368671] hub 5-0:1.0: 2 ports detected [ 1.378763] SCSI subsystem initialized [ 1.408153] libata version 3.00 loaded. [ 1.409213] ata_piix 0000:00:1f.2: version 2.13 [ 1.409245] ata_piix 0000:00:1f.2: enabling device (0005 -> 0007) [ 1.409269] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] [ 1.409367] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 1.427209] scsi0 : ata_piix [ 1.432281] scsi1 : ata_piix [ 1.441185] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xff90 irq 14 [ 1.441197] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xff98 irq 15 [ 1.456181] microcode: CPU0 sig=0x106ca, pf=0x1, revision=0x107 [ 1.496693] atl1c 0000:01:00.0: version 1.0.1.0-NAPI [ 1.525010] microcode: CPU1 sig=0x106ca, pf=0x1, revision=0x107 [ 1.532500] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.608396] ata1.00: ATA-6: WDC WD1200JD-00GBB0, 02.05D02, max UDMA/100 [ 1.608407] ata1.00: 234441648 sectors, multi 16: LBA48 [ 1.608416] ata1.00: applying bridge limits [ 1.625657] ata1.00: configured for UDMA/100 [ 1.625931] scsi 0:0:0:0: Direct-Access ATA WDC WD1200JD-00G 02.0 PQ: 0 ANSI: 5 [ 1.638034] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB) [ 1.638305] sd 0:0:0:0: [sda] Write Protect is off [ 1.638318] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.638433] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.683875] sda: sda1 sda2 < sda5 > [ 1.685008] sd 0:0:0:0: [sda] Attached SCSI disk [ 1.689437] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 1.788044] Refined TSC clocksource calibration: 1795.029 MHz. [ 1.788058] Switching to clocksource tsc [ 1.952046] usb 2-1: new low-speed USB device number 2 using uhci_hcd [ 2.126055] usb 2-1: New USB device found, idVendor=0b35, idProduct=1100 [ 2.126065] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.126072] usb 2-1: Product: Storm Keyboard [ 2.126077] usb 2-1: Manufacturer: Storm [ 2.150973] input: Storm Storm Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input0 [ 2.151170] generic-usb 0003:0B35:1100.0001: input,hidraw0: USB HID v1.00 Keyboard [Storm Storm Keyboard] on usb-0000:00:1d.0-1/input0 [ 2.151271] usbcore: registered new interface driver usbhid [ 2.151280] usbhid: USB HID core driver [ 2.368037] usb 2-2: new full-speed USB device number 3 using uhci_hcd [ 2.529066] usb 2-2: New USB device found, idVendor=0596, idProduct=0001 [ 2.529075] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.529082] usb 2-2: Product: 3M USB Touchscreen - EX II [ 2.529088] usb 2-2: Manufacturer: 3M [ 7.138665] PM: Starting manual resume from disk [ 7.138675] PM: Hibernation image partition 8:5 present [ 7.138680] PM: Looking for hibernation image. [ 7.138994] PM: Image not found (code -22) [ 7.139000] PM: Hibernation image not present or could not be loaded. [ 7.214335] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 9.334216] udevd[334]: starting version 175 [ 9.795928] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1 [ 9.795948] ACPI: Power Button [PWRB] [ 9.796180] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2 [ 9.796197] ACPI: Power Button [PWRF] [ 9.977790] [drm] Initialized drm 1.1.0 20060810 [ 10.140167] iTCO_vendor_support: vendor-support=0 [ 10.141590] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 10.141846] iTCO_wdt: Found a NM10 TCO device (Version=2, TCOBASE=0x0860) [ 10.142881] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 10.355710] i915 0000:00:02.0: setting latency timer to 64 [ 10.400706] coretemp coretemp.0: Using relative temperature scale! [ 10.410070] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining [ 10.410083] [drm] MTRR allocation failed. Graphics performance may suffer. [ 10.410917] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 10.410928] [drm] Driver supports precise vblank timestamp query. [ 10.411048] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 10.411799] fixme: max PWM is zero. [ 10.439970] [drm] initialized overlay support [ 10.482847] fbcon: inteldrmfb (fb0) is primary device [ 10.494859] parport_pc 00:06: reported by Plug and Play ACPI [ 10.494924] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE] [ 10.517725] [drm] Changing LVDS panel from (+hsync, +vsync) to (-hsync, -vsync) [ 10.573358] Console: switching to colour frame buffer device 128x48 [ 10.583117] fb0: inteldrmfb frame buffer device [ 10.583126] drm: registered panic notifier [ 10.583162] No ACPI video bus found [ 10.583271] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0 [ 10.782130] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input3 [ 10.782390] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4 [ 10.782641] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5 [ 11.304499] input: 3M 3M USB Touchscreen - EX II as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input6 [ 11.304865] usbcore: registered new interface driver usbtouchscreen [ 12.964646] Adding 4789244k swap on /dev/sda5. Priority:-1 extents:1 across:4789244k [ 12.999149] EXT4-fs (sda1): re-mounted. Opts: (null) [ 13.316156] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 13.469777] loop: module loaded [ 15.599017] RPC: Registered named UNIX socket transport module. [ 15.599029] RPC: Registered udp transport module. [ 15.599036] RPC: Registered tcp transport module. [ 15.599042] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 15.648982] FS-Cache: Loaded [ 15.696350] NFS: Registering the id_resolver key type [ 15.696405] FS-Cache: Netfs 'nfs' registered for caching [ 15.714421] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 18.181921] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7 [ 20.150718] Bluetooth: Core ver 2.16 [ 20.150775] NET: Registered protocol family 31 [ 20.150783] Bluetooth: HCI device and connection manager initialized [ 20.150792] Bluetooth: HCI socket layer initialized [ 20.150799] Bluetooth: L2CAP socket layer initialized [ 20.150818] Bluetooth: SCO socket layer initialized [ 20.196236] Bluetooth: RFCOMM TTY layer initialized [ 20.196255] Bluetooth: RFCOMM socket layer initialized [ 20.196265] Bluetooth: RFCOMM ver 1.11 [ 20.223728] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 20.223740] Bluetooth: BNEP filters: protocol multicast [ 20.747365] lp0: using parport0 (interrupt-driven). [ 20.966594] ppdev: user-space parallel port driver [ 22.702668] atl1c 0000:01:00.0: Unable to allocate MSI interrupt Error: -1 [ 22.784729] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 209.585515] I-pipe: head domain RTAI registered. [ 209.585533] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 209.585599] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 209.585612] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12465440, CLK_FREQ 1795077000, CPU_FREQ 1795077000 [ 209.585622] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 209.585633] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12465440, 12465440, 12362750 [ 209.661067] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 209.661156] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 209.661169] RTAI[sched]: hard timer type/freq = APIC/12465440(Hz); default timing: oneshot; linear timed lists. [ 209.661178] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1795077000 hz. [ 209.661184] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 209.683528] RTAI[math]: loaded. [ 209.976785] hm2: loading Mesa HostMot2 driver version 0.15 [ 209.995822] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 209.995923] hm2_pci: discovered 5i25 at 0000:02:00.0 [ 209.996494] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 210.053482] Board hm2_5i25.0.7i76.0.0 Hardware Mode 0 = standard [ 210.055541] Board hm2_5i25.0.7i76.0.0 Software Mode 0 = io_spin [ 210.058119] Board hm2_5i25.0.7i76.0.0 Software Mode 1 = io_ana_spin [ 210.061695] Board hm2_5i25.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv [ 210.240698] hm2/hm2_5i25.0: 34 I/O Pins used: [ 210.240709] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output) [ 210.240718] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output) [ 210.240725] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output) [ 210.240733] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output) [ 210.240740] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output) [ 210.240748] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output) [ 210.240755] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output) [ 210.240763] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output) [ 210.240770] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output) [ 210.240778] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output) [ 210.240786] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Smart Serial Interface #0, pin TxData0 (Output) [ 210.240794] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Smart Serial Interface #0, pin RxData0 (Input) [ 210.240801] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort [ 210.240808] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort [ 210.240815] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #0, pin Muxed Index (Input) [ 210.240823] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #0, pin Muxed B (Input) [ 210.240831] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #0, pin Muxed A (Input) [ 210.240838] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 210.240844] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 210.240850] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 210.240856] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 210.240863] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 210.240869] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 210.240875] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 210.240881] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 210.240887] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 210.240894] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 210.240900] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 210.240906] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 210.240912] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 210.240919] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 210.240925] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 210.240931] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 210.240937] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 210.241252] hm2/hm2_5i25.0: registered [ 210.241259] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0 [ 211.729594] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0 [ 211.729608] hm2/hm2_5i25.0: unregistered [ 211.729714] hm2_pci: driver unloaded [ 211.734183] hm2: unloading [ 214.054186] RTAI[math]: unloaded. [ 214.058698] SCHED releases registered named ALIEN PEDV$D [ 214.069493] RTAI[malloc]: unloaded. [ 214.168040] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 214.172770] I-pipe: head domain RTAI unregistered. [ 214.172850] RTAI[hal]: unmounted. [ 351.081978] I-pipe: head domain RTAI registered. [ 351.081992] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 351.082067] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 351.082076] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12465440, CLK_FREQ 1795077000, CPU_FREQ 1795077000 [ 351.082084] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 351.082092] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12465440, 12465440, 12362000 [ 351.099512] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 351.099591] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 351.099603] RTAI[sched]: hard timer type/freq = APIC/12465440(Hz); default timing: oneshot; linear timed lists. [ 351.099611] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1795077000 hz. [ 351.099618] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 351.114397] RTAI[math]: loaded. [ 351.315096] hm2: loading Mesa HostMot2 driver version 0.15 [ 351.319811] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 351.319889] hm2_pci: discovered 5i25 at 0000:02:00.0 [ 351.320837] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 351.377840] Board hm2_5i25.0.7i76.0.0 Hardware Mode 0 = standard [ 351.379899] Board hm2_5i25.0.7i76.0.0 Software Mode 0 = io_spin [ 351.382528] Board hm2_5i25.0.7i76.0.0 Software Mode 1 = io_ana_spin [ 351.386054] Board hm2_5i25.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv [ 351.565662] hm2/hm2_5i25.0: 34 I/O Pins used: [ 351.565674] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output) [ 351.565683] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output) [ 351.565690] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output) [ 351.565698] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output) [ 351.565706] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output) [ 351.565713] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output) [ 351.565721] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output) [ 351.565728] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output) [ 351.565735] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output) [ 351.565743] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output) [ 351.565751] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Smart Serial Interface #0, pin TxData0 (Output) [ 351.565759] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Smart Serial Interface #0, pin RxData0 (Input) [ 351.565766] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort [ 351.565773] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort [ 351.565780] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #0, pin Muxed Index (Input) [ 351.565788] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #0, pin Muxed B (Input) [ 351.565796] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #0, pin Muxed A (Input) [ 351.565802] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 351.565809] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 351.565815] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 351.565821] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 351.565827] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 351.565833] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 351.565840] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 351.565846] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 351.565852] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 351.565858] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 351.565864] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 351.565871] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 351.565877] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 351.565883] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 351.565889] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 351.565895] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 351.565902] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 351.566222] hm2/hm2_5i25.0: registered [ 351.566229] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0 [ 352.366031] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0 [ 352.366048] hm2/hm2_5i25.0: unregistered [ 352.366893] hm2_pci: driver unloaded [ 352.375111] hm2: unloading [ 354.610191] RTAI[math]: unloaded. [ 354.614798] SCHED releases registered named ALIEN PEDV$D [ 354.624605] RTAI[malloc]: unloaded. [ 354.724032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 354.728247] I-pipe: head domain RTAI unregistered. [ 354.728322] RTAI[hal]: unmounted. [ 1504.396041] usb 4-1: new full-speed USB device number 2 using uhci_hcd [ 1504.614083] usb 4-1: New USB device found, idVendor=25a7, idProduct=fa23 [ 1504.614093] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1504.614100] usb 4-1: Product: 2.4G Receiver [ 1504.614105] usb 4-1: Manufacturer: Compx [ 1504.620083] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input8 [ 1504.620600] generic-usb 0003:25A7:FA23.0002: input,hidraw1: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:00:1d.2-1/input0 [ 1504.628144] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.1/input/input9 [ 1504.628887] generic-usb 0003:25A7:FA23.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:00:1d.2-1/input1 [ 1640.597909] I-pipe: head domain RTAI registered. [ 1640.597927] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1640.597994] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1640.598006] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12465440, CLK_FREQ 1795077000, CPU_FREQ 1795077000 [ 1640.598016] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1640.598028] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12465440, 12465440, 12352250 [ 1640.615563] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1640.615651] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1640.615664] RTAI[sched]: hard timer type/freq = APIC/12465440(Hz); default timing: oneshot; linear timed lists. [ 1640.615672] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1795077000 hz. [ 1640.615679] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 1640.641078] RTAI[math]: loaded. [ 1640.844671] hm2: loading Mesa HostMot2 driver version 0.15 [ 1640.848932] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 1640.849047] hm2_pci: discovered 5i25 at 0000:02:00.0 [ 1640.850061] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 1640.907055] Board hm2_5i25.0.7i76.0.0 Hardware Mode 0 = standard [ 1640.909174] Board hm2_5i25.0.7i76.0.0 Software Mode 0 = io_spin [ 1640.911799] Board hm2_5i25.0.7i76.0.0 Software Mode 1 = io_ana_spin [ 1640.915423] Board hm2_5i25.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv [ 1641.095039] hm2/hm2_5i25.0: 34 I/O Pins used: [ 1641.095050] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output) [ 1641.095058] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output) [ 1641.095066] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output) [ 1641.095073] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output) [ 1641.095081] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output) [ 1641.095088] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output) [ 1641.095096] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output) [ 1641.095103] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output) [ 1641.095110] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output) [ 1641.095118] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output) [ 1641.095126] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Smart Serial Interface #0, pin TxData0 (Output) [ 1641.095134] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Smart Serial Interface #0, pin RxData0 (Input) [ 1641.095141] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort [ 1641.095147] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort [ 1641.095155] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #0, pin Muxed Index (Input) [ 1641.095162] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #0, pin Muxed B (Input) [ 1641.095170] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #0, pin Muxed A (Input) [ 1641.095177] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 1641.095183] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 1641.095189] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 1641.095195] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 1641.095201] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 1641.095207] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 1641.095214] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 1641.095220] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 1641.095226] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 1641.095232] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 1641.095238] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 1641.095244] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 1641.095250] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 1641.095256] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 1641.095263] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 1641.095269] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 1641.095275] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 1641.095590] hm2/hm2_5i25.0: registered [ 1641.095597] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0 [ 1641.623970] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0 [ 1641.623984] hm2/hm2_5i25.0: unregistered [ 1641.624094] hm2_pci: driver unloaded [ 1641.628548] hm2: unloading [ 1643.836087] RTAI[math]: unloaded. [ 1643.840439] SCHED releases registered named ALIEN PEDV$D [ 1643.848609] RTAI[malloc]: unloaded. [ 1643.948028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1643.952403] I-pipe: head domain RTAI unregistered. [ 1643.952482] RTAI[hal]: unmounted.
7 years 2 months ago #143802 by andypugh
Toolman321 wrote: HAL: ERROR: function 'and2.0' not found
You can't "addf" the function until you you have "loadrt"-ed the component.
The following user(s) said Thank You: Toolman321
Moderators: newbynobi, HansU
Time to create page: 0.436 seconds
