- Thank you received: 217
The initial activation of the limit switch operates properly, shutting off the machine. Checking the ignore limits checkbox allows the machine to be turned back on and the axis moved off the limit switch. The checkbox also clears. Now, with the checkbox unchecked, moving back onto the limit switch has no effect and the axis can be driven into the hard-stop and crashed. Though I didn't actually test crashing it.
I that sounds right to me, but I count on the limit switches to save me from my own stupid mistakes. My mill is small and on a stand with wheels because I need to be able to move it around in my tiny garage. It's not uncommon for me to turn it on solely to move the table out of the way. I do this without homing it cause it's faster. So, when it's not homed the soft limits are not valid.The limit switch should NEVER be inside soft limits. Think of its as an Oh shit, the world is falling in pin. It needs to be outside the soft limits and should never ever be hit unless something has gone terribly wrong!
Or maybe not. I think I can't test that with a sim config (or with the default sim config). The behaviour is wrong in the sim even with 2.8.0 which I am sure that it isn't on a real machine.Thanks Hans,
Glad to hear you were able to reproduce it.
I just checked for the behavior on 2.8.0, and it's the same. Fails to act on the limit switch activation.
