5 AXIS?
- eighthaxis
- Thank you received: 8
17 Nov 2019 16:24 #150527
by eighthaxis
5 AXIS? was created by eighthaxis
Hello Norbert I had originally installed your older version of Gmoccapy into my 5 axis machining center.
I looked at your newest version and it says it can only run 4 axis. Is this true and if so is there an easy fix? I also read you won't be supporting the older versions.
Thanks,
Josh
Thanks,
Josh
- newbynobi
- Thank you received: 394
17 Nov 2019 20:08 #150543
by newbynobi
Replied by newbynobi on topic 5 AXIS?
Gmoccapy 3.nn does support 9 axis and gmoccapy 2 does support 5 axis and 7 joints.
Did I documented It wrong somewhere?
Norbert
Norbert
- eighthaxis
18 Nov 2019 15:03 #150583
by eighthaxis
Replied by eighthaxis on topic 5 AXIS?
Glad to hear that, thanks for your prompt response.
This is where I read it can only display 4 axis, on page 106 in the Gmoccapy Introduction.:
linuxcnc.org/docs/2.7/pdf/LinuxCNC_Documentation.pdf
- eighthaxis
23 Jul 2020 00:07 #175427
by eighthaxis
Hi Norbert I am back on this project.
I am working on configuring a new .ini and .hal file and when I run GMOCCAPY it tells me I have error and that GMOCCAPY can only handle 4 axis and that my ini file specifies 5 axis.
How do you recommend I resolve this?
- newbynobi
28 Jul 2020 15:13 #176256
by newbynobi
I am am sure you are using an old release of gmoccapy. Update to LinuxCNC 2.8 or master.
Norbert
Norbert
- eighthaxis
28 Jul 2020 18:46 #176274
by eighthaxis
Thanks for your reply Norbert.
OK
I checked I have 2.7.14 which seems to be the only option available from linuxcnc.org downloads page.
Where do I download 2.8?
Do I need to format the hard drive and install a new operating system as well?
Or is there a SUDO terminal command to remove and replace the old version from the terminal?
Thanks,
Josh
OK
Thanks,
Josh
- Thank you received: 7488
28 Jul 2020 19:36 #176275
Replied by tommylight on topic 5 AXIS?
Buildbot.linuxcnc.org
- eighthaxis
28 Jul 2020 19:46 #176276
by eighthaxis
Got it thanks.
- eighthaxis
01 Aug 2020 02:12 #176729
by eighthaxis
WOW! What a supreme pain in the ass.
2 days later got new operating system running:
Debian Stretch /Cinnamon GUI LinuxCNC 2.8
Finally got LinuxCNC installed after about half a dozen hurdles.
Can't someone just make an image that has LinuxCNC working already?
Anyway my new challenge is getting all 5 Axis to work in Gmoccapy.
My new error is:
DEBUG INFORMATION:
Note: Using POSIX realtime
./Bostomatic.hal:262: parameter or pin 'pid.b.Pgain' not found
My new error is:
DEBUG INFORMATION:
- Thank you received: 5330
01 Aug 2020 03:33 #176736
Replied by PCW on topic 5 AXIS?
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s
^^^^^^^^^^^^^^^^^^^^ no pid.b ^^^^^^^^^^^^^^^
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
needs addf pid.b.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i25.0.write servo-thread
Moderators: newbynobi, HansU
Time to create page: 0.997 seconds
