Rapid overide selector switch bounce
- COlger81
- Thank you received: 6
31 Aug 2020 16:01 #180183
by COlger81
Rapid overide selector switch bounce was created by COlger81
I am using a 3 position selector switch to select rapid override value. Values for selector switch are 25%, 50%, and 100%. On startup, the value in Gmoccapy bounces rapidly from these 3 values until i rotate selector switch. After rotating selector, it calms down and acts as it should most of the time. HAL and python file attached.
- Thank you received: 2175
31 Aug 2020 16:52 #180187
Replied by cmorley on topic Rapid overide selector switch bounce
This sounds like fighting between two programs setting the override.
Each program must allow another to set the override without creating an endless loop of changes. I don't know if this is the problem just guessing.
You have chosen a unique way to set the override with a python program.
Usually for a selector switch I would use a mux component and use halui's direct-value option. using a mux16 allows for debounce as well.
This is how pncconf sets up overrides; you could create a dummy config to study the HAL files if you are interested.
It's tough to troubleshoot these kinds of problems because of the highly specific hardware HAL code makes testing impossible for others.
Chris
Chris
- COlger81
31 Aug 2020 17:03 #180188
by COlger81
Replied by COlger81 on topic Rapid overide selector switch bounce
Python seemed like a simple path being that the switch is not just 3 outputs (one for each position). It's a logic setup with 2 outputs.
- newbynobi
- Thank you received: 394
31 Aug 2020 17:08 - 31 Aug 2020 17:08 #180189
by newbynobi
Replied by newbynobi on topic Rapid overide selector switch bounce
Please try to use directly the gmoccapy Hal pin,
Documentation is here
Use this pin and report:
gmoccapy.rapid.rapid_override.direct-value = HAL_FLOAT To adjust the max velocity slider
gmoccapy.rapid.rapid_override.analog-enable = HAL_BIT Must be True, to allow analog inputs
Do never use "enable direct value" and "count-enable", like you did in your Hal file!
Norbert
Norbert
Last edit: 31 Aug 2020 17:08 by newbynobi.
- COlger81
31 Aug 2020 17:13 #180192
by COlger81
I'm using a 3 position selector switch. Not an encoder or potentiometer...
- COlger81
31 Aug 2020 17:16 #180193
by COlger81
I think i see what you're saying.
31 Aug 2020 17:19 #180194
So Norbert has confirmed that GMoccapy doesn't like other programs setting the overrides. , but has HAL pins available to do the same.
So use the GMoccapy pins to set the overrides rather then halui.
the process is similar - pin types and names may be different.
- COlger81
31 Aug 2020 17:21 #180195
by COlger81
Yes, got it sorted now.
Thanks Guys
Thanks Guys
- Thank you received: 7468
31 Aug 2020 18:00 #180201
Replied by tommylight on topic Rapid overide selector switch bounce
Fixed title.
The following user(s) said Thank You: COlger81
- COlger81
31 Aug 2020 18:46 #180210
by COlger81
Was i yelling again? Gotta work on that i guess.
Moderators: newbynobi, HansU
Time to create page: 0.120 seconds
