Help setting up/troubleshooting gmocappy on site Schleswig/Holstein home kiel
5 years 7 months ago #203818 by horntreiber
I am looking for help on site when setting up or troubleshooting gmocappy
Of course,for expense allowance.Control rus so far.Axes run references run. tool lenght measurement worked until recently.
After switching on the control and gmocappy,various error messages apper.
Since I am with the device Stand at war and am not a rocket technican,i would be very happy if
someone was in the schleswig-holstein area kiel agree to help me.
Best tegards
5 years 7 months ago #203947 by newbynobi
What about TeamViewer?
I am in Hildesheim.
Norbert
5 years 7 months ago #204065 by horntreiber
Hello Norbert
when i select a tool from the list ,an error message appears.
The following debugs are in the macros/change ngc folder.
what can i do?
5 years 7 months ago #204150 by newbynobi
Did you change the code? The error tells you, that there is an O used in line 2, so if you have changed line 1 the error could also be reported at line 2.
There has been also a problem with case sensitive o-word stuff, may be you just try to change AL uper o calls to lower letter calls.
Norbert
5 years 7 months ago #204360 by horntreiber
i haven't changed anything.
which settings are correct?
the sensor of the WZLS was defective.i exchanged it for a new one,the sensor is now working properly.
could have something to do with it?
5 years 7 months ago #204367 by newbynobi
IMHO not.
Did you update some time ago?
Have you tried changing the O's in the file from upper to lower?
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.350 seconds
