Help setting up/troubleshooting gmocappy on site Schleswig/Holstein home kiel
5 years 6 months ago #204472 by horntreiber
Hello Norbert
happy Easter
i have changed the O,s to lower. Now the WZLS is working. thank you for your help.
when i loade a test milling job i get an error message.can you please have a look at that.
Thomas
5 years 6 months ago #204562 by newbynobi
First error: You did not touch off in Z, axis 2 and the code does contain a movement what would excide the limits, so on a machine with 100 mm travel distance you try to move to 120
Second error: invalid parameters just check that line and the one above and the following one for typos
Third error no subroutine on aboard found, check typos, seems to be a wrong entry in your INI file or the subroutine path is wrong or...
Why do you use on aboard? Most times it is not necessary, and apologize, you seems to miss basic knowlage, so you might just have on aboard in your inin, because you read it in a docu or so.
Norbert
5 years 6 months ago #204597 by horntreiber
Hello Norbert
thank you first for your patience. as you have already seen, ido not have enough basic knowledge.
i`am already happy to have got the machine running
in addition,i only have simple school english and have to understand many technical terms first
please explain to me exactly what i did wrong and what exactly i have to do for the machine to do a milling job
Thomas
Moderators: newbynobi, HansU
Time to create page: 0.055 seconds
