signal tool change complete with physical panel button
3 years 9 months ago #261115 by HansU
The dialog.py should be on your system as well. But just replacing the files won't in most cases especially NOT if you are running LinuxCNC 2.8 what I assume. This addition is only available in 2.9.
7 months 4 weeks ago - 7 months 4 weeks ago #343800 by depronman
Norbert,
Was the HAL pin for 'manual tool change confirmation dialog' ever implemented ?
I'm in the process of changing from par ports to mesa 7i92 and moving the PC out of the machine cabinet, as such my keyboard hack for a physical button on the control panel to press the 'Enter' key is no longer practical and with the larger amounts of i/p pins on the mesa card I would like to hook the physical button to a mesa gpio i/p pin and use that to clear the gmoccapy tool change dialog popup
now using 2.9.8 latest build
Last edit: 7 months 4 weeks ago by depronman. Reason: added version of linuxcnc
7 months 4 weeks ago #343808 by depronman
answering my own question, the pin is gmoccapy.toolchange-confirm
I connected this in postguihal as below -
net tool-change-button => hm2_7i92,0,gpio.028.in_not <= gmoccapy.toolchange-confirm
Moderators: newbynobi, HansU
Time to create page: 0.168 seconds
