Gcode Error missing something simple
5 years 5 months ago - 5 years 5 months ago #207870 by Gaunt1969
Getting the following error but I don't see anything wrong with line 1.
Just got my system back up and running from a drive crash. Had to reload the OS and now getting this did something change between versions that I have missed.
I am still using the same post processor I have used for the last 2 years to generate the gcode.
The error referenced line one. But it's the % sybole. I thought this has always referenced the start and end of the code
Last edit: 5 years 5 months ago by Gaunt1969.
5 years 5 months ago #207874 by newbynobi
Could you try deleting % at line 1 and in the last line and add a m2 as last line?
May be windows formated line?
Norbert
5 years 5 months ago #207881 by Gaunt1969
I edited it and saved the file, then reloaded and still get unknown operation
5 years 5 months ago #207885 by andypugh
Do you have any remaps or similar active?
Can you attach the G-code file (or at least the first few dozen lines) to a post here?
5 years 5 months ago #207886 by Gaunt1969
Could this have something to do with my Macro and python files for the tool change? I have all my configs backed up from my previous system from prior to my system crash. I was running on the pre-empt when gmoccapy 3 came out.
I just copied them over. I remember that the error messages used to tell you the file location of where they are located if it came from one of those. But with Buster I am not sure
5 years 5 months ago #207892 by Gaunt1969
They should be attached in the top post
Moderators: newbynobi, HansU
Time to create page: 0.401 seconds
