Change language
5 years 5 months ago #209166 by anli
Replied by anli on topic Change language
Thank you! Do you think it makes sense if I create a PR where you can change language settings?
André
5 years 3 months ago - 5 years 3 months ago #216407 by HalaszAttila
Replied by HalaszAttila on topic Change language
Hello,
can you please tell me, how can I activate for example a hu.po translate file?
I compiled Linuxcnc from source, and find the translate files. But i dont know how to activate them.
If i change the linux language, Gmoccapy will follow the system lang, but in this case for some reason the preview path will offsetted. See in this topic:
forum.linuxcnc.org/gmoccapy/32592-tool-p...er-changing-language
Maybe if i just use Gamoccapy with translate file, and the linux system remain on english, maybe the path offset will solved. :)
locale.setlocale(locale.LC_ALL, '')
Maybe this need to edit in gmoccapy.py file?
Thanks for help. :)
Last edit: 5 years 3 months ago by HalaszAttila.
5 years 3 months ago #216625 by newbynobi
Replied by newbynobi on topic Change language
gmoccapy will check the locale settings of the system and set the language automatically.
For testing I just rename the de.po file to be de.old and then the hu.po to be de.po
This is just a work around, but it helps me to see if translation files fit the screen sizes.
Norbert
5 years 2 months ago #216787 by HalaszAttila
Thanks,
i tested it, but it works just if i set linux to Geman language. (de.po -> hu.po)
But if linux is on english language dont works. Becouse no en.po file which to rename to. Maybe the default language is english. Where can i find the english language file? I plan to rewrite it by hand :D
5 years 2 months ago #216888 by newbynobi
try to change gmoccapy.po file.
English is default, so it may be necessary also to change the strings in the code. I have never tried to set a different language while computer is in english. I am using German settings in OS.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.065 seconds
