Setting jog speed on start up in gmocappy
01 Jun 2021 15:08 #210898 by john11668
Is there a way to set the max jog speed on startup ?
When I launch my fast jog rate will be set at 1500 mm/min. It is a small lathe so 750 mm is more manageable, and for touching off I would prefer to see a slow jog rate no more than 45 which I know I can then reduce to suit my job.
I have hunted around the files for a parameter or a scale factor which would give me the above.
Any ideas what settings i need and where ?
TIA
01 Jun 2021 15:31 #210899 by tacklem60
Replied by tacklem60 on topic Setting jog speed on start up in gmocappy
It is actually a really easy setting to change in your configuration. Just change the Default Jog Speed in your .ini file or even easier, the setting menu or Gmoccapy allows you to change it and that will be the speed at startup.
That, however, will not change in any way the "max" speed as you referenced. It will always allow you to move the speed slider to your max jog rate or if using a keyboard, holding shift and the direction will give you max jog speed.
You can also change the scale of your turtle jog inside the settings of Gmoccapy if you wanted to make that scale at a different rate.
01 Jun 2021 17:58 #210901 by john11668
Replied by john11668 on topic Setting jog speed on start up in gmocappy
I dont see a default jog speed in my ini file . ( and I see no step in the step config wizard to generate a default jog speed
And the only related figure I see in the settings page is a scale jog velocity for mpg which does not seem to affect anything ( I dont have an MPG)
Can you point me to what i should see please
01 Jun 2021 21:25 #210915 by Clive S
Replied by Clive S on topic Setting jog speed on start up in gmocappy
Can you post your hal and ini files
02 Jun 2021 01:48 #210931 by phillc54
Replied by phillc54 on topic Setting jog speed on start up in gmocappy
see DEFAULT_LINEAR_VELOCITY @ linuxcnc.org/docs/2.8/html/config/ini-co...tml#_display_section
The following user(s) said Thank You: john11668
04 Jun 2021 13:16 #211155 by john11668
So I am not seeing anything relevant in my Hal or Ini files maybe this is just part of my unfamiliarity wtih linux
Do you guys ?
04 Jun 2021 13:57 - 04 Jun 2021 13:57 #211157 by Clive S
Do you guys ?
In the display section of the ini
Try changing
DEFAULT_LINEAR_VELOCITY = 25.00 to 10.00
Last edit: 04 Jun 2021 13:57 by Clive S.
04 Jun 2021 15:00 #211163 by john11668
Will give it a shot,
04 Jun 2021 15:21 #211164 by john11668
changed that but still opens up at 1500
Tried changing max linear velocity too but no difference
04 Jun 2021 15:54 - 04 Jun 2021 15:58 #211165 by Aciera
Replied by Aciera on topic Setting jog speed on start up in gmocappy
Try changing
I believe you need to do this in the [TRAJ] section, not in the display section.
[edit]
'turtle' jog can be adjusted in the 'settings page' -> 'Hardware tab' at the bottom 'Turtle Jog'
Last edit: 04 Jun 2021 15:58 by Aciera.
The following user(s) said Thank You: Clive S, john11668
Moderators: newbynobi, HansU
Time to create page: 0.748 seconds
