wrong dro after start, and axis tool change window
4 years 11 months ago - 4 years 11 months ago #226658 by DoWerna
apparently not after all
after the reinstallation everything worked.
after homing were always immediately displayed the correct values in the DRO.
Have now switched to the Gmoccapy Toolchange window...
I have really only edited the configuration files and started some previus configs for testing
now shows me after the homing again the machine constants, instead of the selected G5X coordinate system.
Last edit: 4 years 11 months ago by DoWerna.
4 years 11 months ago #227277 by DoWerna
Am I really the only one with this "problem"?
Of course, this is not really a big deal now.
You only have to call up the coordinate system again and the values are correct.
I would find it only strange that with me a bug occurs, which has no one else.
Means for me that I have somewhere an error in the configuration or installation....
4 years 11 months ago #227287 by newbynobi
I do not see any error in INI or hal files. It is very strange, that your machine starts with G58.
Actually I have no time to get deeper into this, but I will have it on my to Do list.
What hapens if you start a sim config?
Norbert
The following user(s) said Thank You: DoWerna
4 years 11 months ago #227341 by andypugh
Maybe delete the linuxcnc.var file? Possibly that has an accidental persistent entry.
4 years 11 months ago #227379 by DoWerna
strangely, when I start a simulation are immediately displayed the correct values in the dro.
Yesterday I also copied my configuration into a new folder and deleted all files except the *.hal and *.ini.
so even without *.var *.pref starts the DRO wrong.
4 years 10 months ago #229412 by DoWerna
another thing in this context today.
When I run a program that uses G55, for example, the DRO displays the correct values, but the values in the DRO are labelled G54 instead of G55.
Moderators: newbynobi, HansU
