Question: Gmoccapy 3.4.2 and touchscreen
3 years 8 months ago - 3 years 8 months ago #265156 by 0x2102
The problem is with Gmoccapy 3.4.2.
I have installed a fresh copy of LinuxCNC ISO with 2.8.4 - did a test and then upgraded to 2.10 (master).
On 2.8.4 it's working fine, but not on 2.9/2.10 with Gmoccapy 3.4.2
Last edit: 3 years 8 months ago by 0x2102.
3 years 8 months ago #265267 by HansU
Thanks for your testing. I have actually no idea right now. I created an issue here: github.com/LinuxCNC/linuxcnc/issues/2361
The following user(s) said Thank You: Funny
3 years 3 weeks ago #282522 by newbynobi
I am trying to solve the problem, unfortunately I am not at home and got no touch scrren here.
Could you try:
- Go to settings page
- select mouse button mode (the 5. entry should be the active one)
- change the settings from the 5.entry to the 3. one
- Try to move the preview around
IMHO that is the entry axis is using
Report back.
Norbert
3 years 2 weeks ago #282933 by 0x2102
Hi Norbert,
I just tried that but it didn't made a difference. Same problem.
Regards,
Markus
2 years 11 months ago - 2 years 11 months ago #286565 by pistrix
I have just updated to LinuxCNC 2.9 and I have exactly the same problem. :( I wonder if anything has been solved about this?
Jan
Last edit: 2 years 11 months ago by pistrix.
2 years 5 months ago #299886 by kofsky0328
I also encountered the same problem, unable to use the touch screen to drag the preview interface, linuxcnc2.9.2, gmoccapy3.4.6
Moderators: newbynobi, HansU
Time to create page: 0.069 seconds
