Raised Spindle - What a mess
3 years 6 months ago #269459 by Jeff_in_Wa
I'm using v2.8.2 Linuxcnc - Debian Buster /  Gmoccapy ui
Machine is a cnc router (PrintNC)     X, YY, Z
For the last year, I have been using this machine and it has been working flawlessly
Then I decided to raise the spindle so that I could get my probe over a part I'm working
on...  That was a mistake!   I only raised the spindle a half inch...
Now when I probe bar stock (xyz), run the tool setter(M600, M6), start machining, the end mill
is cutting air about 2.5" above the bar stock.  I watch the probe routine working, each axis being
zeroed out on the dro.
Why am I cutting air now?   Did I dink with some stored spindle height variable?
3 years 6 months ago #269467 by newbynobi
Without your config it is not possible to answer the question, as there are to many possibilities.
You raised the spindle to get your probe over the part?
So you moved the spindle and the probe?
In gmoccapy you can set blockheight and probe hight etc. have you checked your settings?
Norbert
3 years 6 months ago #269469 by Jeff_in_Wa
Thanks Norbert. Yes, I raised the spindle up a half inch to get the probe over the part. That's it.
Now when I use the probe, and tool setter, then start a job, the end mill is cutting air about 2"+ above the part. I have checked the post a number of times.
I'm wondering if there is a variable set somewhere that has the old spindle height.
3 years 6 months ago #269472 by newbynobi
3 years 6 months ago #269620 by Jeff_in_Wa
Here is what I know for sure
This all started when I raised my spindle a half inch up in it's mount
From that time, I have NOT been able to use my probe where I don't end up cutting air after using M600, M6 T99
If I bypass the probe, and set the tool manually, still using M600, M6 T99, the job runs fine.
Yes, the probe routine is setting the three axis's to zero on the DRO
Something changed when I raised the spindle up. This is what started the issue with my machine.
To me, the M6 routine isn't calculating the offset now. And I have no idea. If I run a second tool change on the job I'm running, the Z will be off.
3 years 6 months ago #269623 by tommylight
You did not provide config files as requested by NewByNobi
That is to be expected, the machine does not know you raised the gantry, it has to be told by editing stuff to match the new reality.
Insisting on it will for sure not fix it.
Or will it...
Moderators: newbynobi, HansU
Time to create page: 0.065 seconds
